b20 turbo times, opinions?
i finally got to run my turbo b20z yesterday at the track, i was kinda disapointed but maybe i should be happy??i ran on yoko 205/45/15's and with a crappy 2.5 60ft i manged to get a 14.23@102.......the car is a 92 si hatch with power doors and a bunch of other dodads and that was only on 6psi.....is this decent?? i was hoping for like 13.5's........
Re: b20 turbo times, opinions? (TwistedHatch)
you have obvious traction problems here and your not really running that much boost. so don't feel too bad. that trap should get a high 13's pass out of your car without much effort.
my solution would be turn up the boost but hey that's always my solution.
any dyno time what kind of management blah blah blah, let us know.
Re: b20 turbo times, opinions? (gsR-T mode)
He has stock block b20z with stock b20 head and everything stock stock stock. Dustin is running fmu and missing link wiht walbro pump. I think he is getting hondata soon.
Haha nicks Ls/vtec beat you ahaha thats funny ****
Re: b20 turbo times, opinions? (ghettocrxsi)
ya nicks car was close...but he could only run 14.4 and he was gettin like 2.1 60ft....... but yea i wanna get my hondata soon, but i need to do something about the lean condition before i blow the thing up....the setup is a bone stock b20z.....i'm running a drag gen 3 man. and tial wastegate....it's a closed loop wastegate setup with a 2 3/4 dp and it's a t3/t04e turbo, i have a ls trans with r final drive and diff, wich should have given me better 60ft then it did, but oh well, i need to get some better tires....i'm gonna try to run some 225/55/15 nitto 555r's on my next venture to the track and see if i can do any better......
ive seen stock b20s with 6 psi run low-mid 13s with drag radials and a vx...si a bit heavier....mostly id say its your tires and launch practice
Re: b20 turbo times, opinions? (JDM_SiR_II_EG)
youre just going to have a lot of traction problems being so torquey and all. try dropping the pressure in your tires and see if that helps some, and feathering the throttle more(dont just drop the hammer)
well you know what I think you should let your friend drive your car cuase they can always out drive you and maybe your car would run fast and I still have the fastest time dustin ahhahah 14.21 hahahaha you can't beat me and that was all motor.
Re: b20 turbo times, opinions? (jdmhatch138)
hahahhahah yea yea yea.......all motor cars a bit easier for me to drive, since this is my first turbo car that has lasted more then one week....... and this is the very first time i've had it at the track and it's alot diff then a all motor car, the power delivery is way way diff......but i'm gonna get some nitto drag radials and try to hit low 13's, and i need the fpr and guage you got there buddy.....
X2BOARD
08-20-2014 10:09 PM
