b20 turbo project wont start ..help
Old Jun 21, 2009 | 02:28 PM
lookout22's Avatar
Default b20 turbo project wont start ..help
i have a 92 integra and i put a b20 engine in it. i did everything the same as the b18. i even swapped the b18 intake manifold. It cranks, get spark and fuel.no start. Ugh. its really annoying. Any suggestions? What should i check now? any help would be appreciated. I have no idea why it wont start.
Old Jun 21, 2009 | 02:51 PM
reddcoupe's Avatar
Default Re: b20 turbo project wont start ..help
yo bro u not alone i got the same problem with my turbo ls check make sure all ur grounds are good try a different computer also check the timing
Old Jun 21, 2009 | 03:18 PM
lookout22's Avatar
how many grounds are there?
Old Jun 21, 2009 | 04:17 PM
lookout22's Avatar
come on guys i know somoene out there can help me out
Old Jun 21, 2009 | 05:45 PM
reddcoupe's Avatar
one from engine to the body and one from tranny to body
Old Jun 21, 2009 | 05:48 PM
lookout22's Avatar
yea thats what i thought. The one from my tranny to the body is all frayed and messed up. do you think that could mess me up?
Old Jun 21, 2009 | 06:17 PM
lookout22's Avatar
has anyone ever found a crappy ground to really keep an engine from starting though?
Old Jun 21, 2009 | 06:51 PM
reddcoupe's Avatar
yea a crappy can stop u from starting my car almost caught fire and there was no spark
Old Jun 21, 2009 | 07:34 PM
gutted-dx's Avatar
Check the ground on the Thermostat, and on the tranny. Both will keep it from starting.
Old Jun 22, 2009 | 09:23 AM
tepasoelrolo's Avatar
thanks for your comments the only thing i can tell u is that when i just installed my b20 it did the same thing it cranked over but nothing what i did was i changed my 450 injectors back to stock since i dont have a fuel pressure regulator and the bitch started right up thats what i can tell u but also check the grounds
Old Jun 22, 2009 | 09:48 AM
Joseph Davis's Avatar
Here's the holy trinity of diagnosis: Fuel, Fire, Compression?
Old Jun 22, 2009 | 11:08 AM
lookout22's Avatar
i dont see how my fuel injectors would do anything. i just had them working on my b18 right before i started this swap.
Old Jun 22, 2009 | 11:22 AM
philafelman's Avatar
are the ignition wires on in the correct order and is your cam timing ok?
if those are good, do a compression check.
Old Jun 22, 2009 | 05:04 PM
omgwtfbbq's Avatar
try removing the dizzy, rotating the rotor 180 degrees, and bolting it back on.
Old Jun 22, 2009 | 07:53 PM
reddcoupe's Avatar
do the compression test i had the same problem compression was sucker that keep it from starting
DC2Terror
Jan 22, 2013 04:43 PM
lookout22
Jun 21, 2009 04:16 PM
b20integrapower
Oct 18, 2006 02:22 PM
integturbo
Jan 10, 2006 03:05 PM
