B18C1 temp sensor question
No-Traction = Fun
I have an AEM water temp sensor and I was wondering if I can use the port on the back of the block here. Where is everyone getting there water temp from?
Not sure if where u picked would work or not. What I did was tapped the bleed thing on the thermostat housing. All u gotta do is drill so the tip of the sensor will go the whole way in. And the threads r almost exactly the same (atleast with my defi sensor) I ran a tap in twice and she's tight as can b. hope this helps.
Temp sensors are traditionally installed in the cylinder head as the coolant temps are always higher there. I personally prefer getting it from the head myself - better accuracy.
90LSpimpin
Nov 1, 2004 08:37 PM
aem, b18c1, doesnt, fit, heat, location, senor, sensor, switch, temberature, temp, temperature, thermostat, water
