B18C1 temp sensor question
Old Jul 11, 2011 | 11:48 AM
CaliforniaDad's Avatar
No-Traction = Fun
Default B18C1 temp sensor question
I have an AEM water temp sensor and I was wondering if I can use the port on the back of the block here. Where is everyone getting there water temp from?
Old Jan 28, 2014 | 06:54 AM
prahaian's Avatar
Default Re: B18C1 temp sensor question
bump
Old Jan 28, 2014 | 10:52 AM
digital sol's Avatar
I thought most people just drill/tap the thermostat housing?
Old Jan 28, 2014 | 11:35 AM
sleepencivic's Avatar
drill and tap the front block plug some people use it for coolant feed line for turbo
Old Jan 28, 2014 | 11:51 AM
tepid1's Avatar
I used a fitting in the side of the head, but I don't use the OEM dash anymore. It was originally the temp sensor for the dash cluster.
Old Jan 28, 2014 | 12:03 PM
boostlsveg's Avatar
Not sure if where u picked would work or not. What I did was tapped the bleed thing on the thermostat housing. All u gotta do is drill so the tip of the sensor will go the whole way in. And the threads r almost exactly the same (atleast with my defi sensor) I ran a tap in twice and she's tight as can b. hope this helps.
Old Jan 28, 2014 | 01:40 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Temp sensors are traditionally installed in the cylinder head as the coolant temps are always higher there. I personally prefer getting it from the head myself - better accuracy.
Old Jan 28, 2014 | 02:05 PM
lsturbo33's Avatar
The date says he posted this in 2011.
Old Jan 28, 2014 | 04:58 PM
DO IT ON ALL FOURS
Yeah... I was answering the dumb n00b that bumped it. Either way this should be locked.
Old Feb 28, 2014 | 09:18 AM
No-Traction = Fun
Just a test
ThumperDumper
Jun 26, 2013 06:54 PM
solrickCC
May 27, 2006 12:44 PM
90LSpimpin
Nov 1, 2004 08:37 PM
