B18C1 Hatch turbo selection
Old Aug 13, 2008 | 04:51 PM
revlimitx04's Avatar
Default B18C1 Hatch turbo selection
In a 93 Hatch b18c1 as a DD street car what turbo size would be best?
Stock b18c1, no more than $5.5k for entire turbo setup, daily driven car, i was hoping you guys could give me that information on what rpm to boost, im in the works of acquiring a b18c1 from HMO or IAS, was unsure when id like to spool since ive never driven a b18c1. I had a h22a in a 98 lude before this hatch.
Stock b81c1 for now, unless i can get away with having the motor built for under $2k in TX.
Modified by revlimitx04 at 2:55 PM 8/14/2008
Old Aug 14, 2008 | 11:02 AM
Default Re: B18C1 Hatch turbo selection (revlimitx04)
Old Aug 14, 2008 | 11:07 AM
r33dm0n3y's Avatar
you need to add more info if you want a response, well an educated one at least.
>what are your horse power goals?
>any plans to build engine?
>at what rpm would you like boost?
>budget?
Old Aug 14, 2008 | 12:53 PM
Default Re: B18C1 Hatch turbo selection (r33dm0n3y)
edited in more info
Old Aug 14, 2008 | 08:38 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
i even put the amount cause I was trying to see the least I could spend on this set up. Im married now. I live kinda local to you so if you need help....when you get the parts let me know, i'll come to you
https://honda-tech.com/zerothread?id=2345402
Old Aug 15, 2008 | 09:19 AM
Default Re: B18C1 Hatch turbo selection (HybridcivicLS-T)
I just moved from Ausitin up here to Granbury. I talked to tony via pm and he said T1 does engine builds, im gunna see how much itll cost to get the engine boost ready, is your b18c1 stock making 333hsp? If so i dont even need to build the engine, 330 horses would be plently for what I want, i might have to copy your setup man. It looks sick, your engine bay is sparkly clean also. Ill be ordering the b18c1 from HMO or IAS in a few months, after that will have to save a few thousand for the turbo, and ill end up trailoring it up to Rowlett for T1 tune. I belive Benbrook (30mi) from here has a autocross track aswell.
PS: what are the key things to make sure are 110% for the final tune, i noticed in your thread you had trouble with the solonoid and your wires?
Old Aug 15, 2008 | 10:07 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
i used to live in fort worth. I have friends that live in benbrook. The trqack is actaully in cresson right outside of grandbury.
anyway, those things happen sometimes. wasn't really trouble i just didn't know until we put the car on the dyno. The good things about Tony is he's really good at diagnosing problems. Im not bad myself but i didn't have another solenoid at home to test out. To find out i was right and we just changed it out. the wirng. i assumed that i had a 12v source and never choose to check it, then found out it wasn't so i just switched it at the dyno. that was no big deal.
just have everything ready the best you can it makes the dyno session smooth and not looking for stupid problems.
Old Aug 15, 2008 | 04:54 PM
Does the track outside cresson have safety requirments, ie: rollcage / harness / helmet rule or can you take a stock car out for runs? Like to do a comparrision, a before and after. And by chance do you know how much it runs to use the track?
If not ill just give them a call lol.
Old Aug 17, 2008 | 07:38 PM
TheShodan's Avatar
Moderator
https://honda-tech.com/zerothread/2367966
here ya go. read my post
Old Aug 18, 2008 | 01:33 PM
Default Re: (TheShodan)
T3/t67
SLIM NOTHING
Jan 25, 2011 11:28 AM
HS2G
May 30, 2004 06:11 AM
Officer
Dec 10, 2002 05:52 PM
NiGhtRiDa
Apr 7, 2002 12:35 PM
