B18C1 boost build up, what to do to the engine before the swap?
Old Jan 3, 2003 | 08:30 AM
Carp's Avatar
New User
Default B18C1 boost build up, what to do to the engine before the swap?
I am about to start my B18C1 swap into my 88 crx. I plan on getting the engine in and running, and then about a week later putting on a turbo, probably a max-rev turbo setup like my brothers (DOHCarp)
what should I do to prep the engine for boost.
I am trying to get 10 or more psi out of the setup on a stock bottomend.
I already have skunk2 IM and heavy duty ACT, and chipped p28
what type of things can I do without doing internal work.
thanks for the help
Craig
Old Jan 3, 2003 | 12:10 PM
Carp's Avatar
New User
Default Re: B18C1 boost build up, what to do to the engine before the swap? (Carp)
anybody? what would you do if you were going to put a turbo on a b18c1? Im just looking for some ideas, so I can save time and do it while the engine is out of the car.
Old Jan 3, 2003 | 06:42 PM
avividmemory's Avatar
upgrade your fuel system to at least 450's and go with hondata or a vafc hack if your short on cash
Old Jan 3, 2003 | 07:05 PM
Tofurky's Avatar
10 psi will be pushing it. other people will tell you otherwise though.
if you want to boost more on a stock bottom end, look into a thicker headgasket, like inlinepro's or a cometic.
and definitly look into hondata, 550's, warlbro intank pump - and getting it dyno tuned
Old Jan 4, 2003 | 02:24 PM
Danger's Avatar
Default Re: B18C1 boost build up, what to do to the engine before the swap? (Ruckus138)
how many miles are on the motor ?
maybe change the timing belt , oil pump , water pump , etc...
just a few ideas that might help you out .
IcebergMan
Sep 15, 2005 06:05 PM
VTcivicEG
Jul 18, 2004 04:31 PM
slyph777
Aug 14, 2003 06:48 AM
mitchb
Jan 3, 2003 04:31 AM
Racer X
Oct 16, 2002 08:59 PM
