B18c Oil cooler / heat exchanger
My original plan was to use the OEM oil to water heat exchanger. I am now planing to use water cooling on my turbo as well. If you think about it a water cooled turbo is pretty similar cooling of the hot oil with coolant.
My question is this can i use both? or would it be too much strain on the cooling system. I do have a an upgraded Radiator 3" aluminum similar to mishimoto style.
any input or recommendation would be great
Re: B18c Oil cooler / heat exchanger
no just help longevity of the turbo.....or should I ditch the heat exchanger and just use a water cooled turbo setup
Moderator
Don't over complicate things. Water cooling the turbo is fine.
http://www.turbobygarrett.com/turbob...er_Cooling.pdf
Oil cooler can work as well, but needs a dedicated air flow source. If its a regularly street driven car, not all that necessary.
Thanks for reply!. its not a traditional oil cooler that requires air at all but I was starting to think the same. Ill just sell it Thankyou
