Help Tranny making tuck tuck noise with Quaife LSD??? Help
Hey guys i know its the wrong forum i posted in TECH but no answers.
Ok we installed a quaife LSD in a B16A tranny all new bearings go for a drive acels fine all gears but on deceleration there is a light tuck tuck tuck noise.
Im wondering if its the LSD cause it is new and there is maybe no oil worked init or i need to do some figure 8' for a bit to get it to work in???
Anyone can help me
Anyone can help me
Re: Help Tranny making tuck tuck noise with Quaife LSD??? Help (JDMCRX)
well, the quaife is sealed, so you dosnt have an oiling problem.
I never did the "figure 8" break in with mine, and I never had any issues...
Did you measure & get the correct clearance diff shim, or did you just drop it in with the stock shim? Perhaps the diff moves axially on deceleration, _just_ hitting something on the secundary shaft...?
Otherwise it may be in the diff itself- I've read some other reports about the diff being noisy on decelerating (here's a thread you may find interesting: http://www.hostboard.com/cgi-b...11970).
My Quaife's still running great btw, no noises yet.
Mark.
Mark.
My car also has a quaife diff and clunks when corning on the gas, even just a little bit of gas, straight its fine, left and right fine out of gear or with the clutch on is fine and even clutch off in gear at idle rpm, but on the gas and turning it sounds like its going to blow apart, reverse is even fine on or off the gas, i already changed my motor mounts and axels, anyone know if this is the quaife diff?
