b18b Turbo smoking !
Old Jul 11, 2009 | 03:12 PM
JAYDmManny1331's Avatar
Default b18b Turbo smoking !
well i have a 98 integra with an ls turbo t3/t4 turbo and it runs fine and strong but when i stop at a light or let it just idle smoke starts coming out lot of smoke is my turbo blown or maybe seals or can it be my head gasket ??
thanks guys hope you can help !
Old Jul 11, 2009 | 06:45 PM
mtber's Avatar
Default Re: b18b Turbo smoking !
1. Complete a compression test to ensure it's not a motor issue.
2. Make sure your return line isn't getting backed up due to improper positioning etc.
3. Look at the turbo inlet for signs of oil leaks...
4. Assume your turbo seals are on the way out...
Old Jul 11, 2009 | 07:00 PM
kreatekustomz's Avatar
Even if compression tests shows a cylinder with a percentage of difference I still wouldnt count out that turbo. I made the mistake of assuming I had a bad piston ring when one of my cylinders showed 30psi difference than the rest. pulled the motor took it apart and turned out to be a mistake by the previous builder, but the real problem was the turbo. Same problems your having.
To count the turbo out just unbolt it let it idle see if it smokes...
Old Jul 11, 2009 | 09:04 PM
alright guys thanks for the input im putting a b20 in anyway but there seems to be sign of oil in the intercooler so i think the turbo seals are gone because the motor still spools !
Old Jul 11, 2009 | 09:56 PM
JDMDC5nEG's Avatar
I just recently had to replace my t3/t4 because the seals were bad...when I took the downpipe off it was full of oil where the flang bolts to the turbo. It smoked like a freight train, then I installed my 60-1 and not a bit of smoke.
Old Jul 12, 2009 | 08:54 AM
how much did it cost you to replace it man !! it isnt that hard to replace the turbo im thinking of just changing the seals my self
Old Jul 13, 2009 | 05:23 AM
Axix24's Avatar
try running some 10w40 oil and running an oil restrictor and report back if it still smokes.. Try that before you take the turbo off...
Rob!
Dec 18, 2004 03:08 PM
Hoosier Daddy
Mar 24, 2004 01:20 PM
VTgringo
Jul 1, 2003 06:44 PM
Dorikamu
May 2, 2002 01:09 PM
