B18b turbo camshaft question
My friend who grinds cams is making me custom cams for my Ls-T setup with the oem cams, I was just wondering if I would need to upgrade the valvetrain as well or would it be fine.. Thanks
Do you even PLEBE R8?
Re: B18b turbo camshaft question (Panda Eg6)
Well first i would ask how aggressive will the regrinds be, but either way anything above factory specs i would definitly upgrade. Its really not that expensive and like stated is worth not floating a valve. Mainly i would be worried if you were plannin on revving higher than factory redline.
Re: B18b turbo camshaft question (ForceFed Motorsports)
Yea that is a good point, if I ended up not putting in aftermarket springs then I would definately not rev over the stock redline.
I think I well end up buying some valve springs, also wanted to know if it was worth buying retainers as well- or if that is just a waste of money.
Also I am doing my build with a budget and was wondering what kind of valve springs you guys would recommend.
Thanks
Thanks
You can find combo sets that are a good deal with both springs and retainers. I would recommend it while your in there. Do it once and do it right
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ForceFed Motorsports »</TD></TR><TR><TD CLASS="quote">You can find combo sets that are a good deal with both springs and retainers. I would recommend it while your in there. Do it once and do it right </TD></TR></TABLE>
True
Thanks
True
Thanks
the.hamburglar
12-27-2005 04:03 PM
dohcter g
10-17-2003 05:17 PM
CRXSleeper
09-09-2002 10:47 PM
