b18b turbo?
Old Aug 14, 2009 | 06:55 AM
crxb16a90's Avatar
Default b18b turbo?
i have a few question about engine build for turbo
plan on building my b18b bottom end up with forged wiesco and eagle rod. running around 9.8 to 1.
will stock block able to bore to 20over? thats 81.5mm right?
i also want to run about 14lbs boost (tuned of cuz)
will the stock sleeve still able to hold with block guard installed, i just wonder since the block been bored out?
i will resleeve another engine but it be around 8months before i can afford sleeving. thx
Old Aug 14, 2009 | 12:17 PM
blackeg's Avatar
Default Re: b18b turbo?
dont even bother with the block guard.
why 14 psi, where did u get that number from? to do it properly you need an aftermarket map sensor and to get tuned for it.
Old Aug 14, 2009 | 12:38 PM
Whatever's Avatar
There is an 800+ page thread in this section that will answer any and all questions you could possibly have about a B18b turbo...
Old Aug 15, 2009 | 06:39 AM
crxb16a90's Avatar
plan on using aftermarket map sensor, of cuz get it tune.
so far for the 14lb, i heard b18 can only take up to 16lb. so i was thinking 14 for the safe side.
ok, lets just try this then.
i got a integra ls. got a drag turbo kit.
i'll have 2800 to use in september and 3000 to use around feb.
if u in my situation, what would u do on build?
Old Aug 15, 2009 | 07:45 AM
pumpkinz6's Avatar
dont need the block guard. i would throw in some arp head studs. people run like 18-20psi on stock b18b's with arps to avoid headlift frequently. like someone said above me theres a thread on here about boosted b18b's that can answer every question u could have as well as show u alot of setups for reference.
Old Aug 15, 2009 | 11:23 AM
crxb16a90's Avatar
alright, gave me idea what i need to start with. thanks everyone
Old Sep 13, 2009 | 07:50 PM
SS760's Avatar
Can you send me that link?
Old Aug 26, 2010 | 10:27 PM
dally171's Avatar
Icon2 Re: b18b turbo?
can you please send or post the link to the 800 page b18b turbo thread,
thanks in advance
Old Aug 26, 2010 | 10:35 PM
Silva Bullit DC4's Avatar
thanks in advance
https://honda-tech.com/forums/forced-induction-16/lst-ls-t-turbo-b18a-b18b-setups-1323059/
To the OP, always set a horsepower goal, not a psi goal. Your tuner will use whatever psi your setup will give him to make that goal. And don't bother with the block guard. What will be the purpose of the car? Drag? Daily? Both?
Old Aug 26, 2010 | 10:38 PM
fasthatch95's Avatar
After i sleeved my b18b1 i was never happier! it just sits in my room the rest of the build is cake, you even have more cash than i did @ the time.
The Civic Project
Dec 29, 2004 02:19 PM
6shootahorsenamedtrigga
Dec 15, 2004 09:54 PM
mz3bo
Jul 19, 2003 08:13 AM
DjFreeze
Jan 22, 2003 09:22 AM
VR_GS-R
Nov 12, 2001 11:06 AM
