putting b18b pistons in a b17a
Old May 31, 2005 | 04:33 PM
tegturbo's Avatar
Default putting b18b pistons in a b17a
what would this give me for comp. i broke the ring lands on my pistons and i have a set of b18b piston here that are almost new. thanks for any help.
Old May 31, 2005 | 06:29 PM
IMPORT JEDI's Avatar
Default Re: putting b18b pistons in a b17a (1.7turbo)
your comp would be 9:1
Old May 31, 2005 | 06:39 PM
tegturbo's Avatar
Default Re: putting b18b pistons in a b17a (IMPORTJEDI)
thanks it should be more streetable with 10lbs of boost and still make good power.
Old Jun 1, 2005 | 03:48 AM
tegturbo's Avatar
anyone do this before if so how did it work
Old Jun 1, 2005 | 07:25 PM
tegturbo's Avatar
bump
Old Jun 1, 2005 | 07:35 PM
_entropy's Avatar
Ever stop and think, if you blew B17A ringlands why can't you blow equally weak B18B ringlands?
https://honda-tech.com/zerothread?id=1181347
Spend 800 bucks on good pistons and rods if you're tearing the motor apart.
Old Jun 1, 2005 | 09:38 PM
G
sh!t happens.
Default Re: putting b18b pistons in a b17a (Napoleon Dynamite)
just sell me your b17a blcok
Old Jun 1, 2005 | 10:45 PM
DohcVtecCrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Napoleon Dynamite &raquo;</TD></TR><TR><TD CLASS="quote">Ever stop and think, if you blew B17A ringlands why can't you blow equally weak B18B ringlands?
Spend 800 bucks on good pistons and rods if you're tearing the motor apart.</TD></TR></TABLE>
Ever stop and think, if he broke ring lands at 10 psi, he has a tuning problem. So your right prolly blow the b18b pistons too AND any other after market pistons you put it. The problem is the tune not the pistons. No super duper pistons is gonna fix a lean condition. They burn and blow just the same.
I'd say a better route than aftermarket pistons, is throw the b18b ones in and have it dyno tuned
Old Jun 2, 2005 | 03:47 AM
tegturbo's Avatar
Default Re: putting b18b pistons in a b17a (DohcVtecCrx)
ya you are right i did stop and think i didnt have it dyno the first time . this time its gettin tuned as soon as its broke in.
Adampops
Jan 9, 2002 01:30 PM
