Is the b18a1 and b18b1 the same bottom end?
Old Apr 5, 2011 | 05:35 AM
protopro88's Avatar
Default Is the b18a1 and b18b1 the same bottom end?
I just cracked a cylinder wall on my boosted 94 civic lsvtec. It had a b18a1 block in it. My question is can i use a b18b1 block to replace it without having to get a tune. Or is it better for me to just find a b18a1? Thanks
Old Apr 5, 2011 | 05:37 AM
guy_from_nerk's Avatar
Default Re: Is the b18a1 and b18b1 the same bottom end?
They are the exact same motor minus obd1/obd2 having a different intake manifold and ecu, so yes they are the same.
Old Apr 5, 2011 | 06:09 AM
protopro88's Avatar
Will the obd1 harness plug right into the block?
met-tuning's Avatar
yes the odb1 harness will work just fine
Old Apr 5, 2011 | 06:19 AM
protopro88's Avatar
O ok. Is one stronger then the other
Old Apr 5, 2011 | 10:04 AM
No...they are the same engine!! Yes your harness will plug right up
Old Apr 5, 2011 | 11:00 AM
BigMike0147's Avatar
From what I understand, they are slightly different engines. I believe the B18B has a few more horses stock due to some differences in the head. So, to answer the question, the blocks should be the same.
Old Apr 5, 2011 | 02:56 PM
The extra 10hp comes from the intake manifold design and the ecu tuning like i stated in a previous post. The heads are identical, the cams are the same (big honda myth that a1/b1 cams are different), look up the part numbers for gods sake if you don't wanna listen/believe me. I have personally seen b18a/b and auto vs manual cams mic'd, they all came back with the same specs....(not trying to be a dick to the above poster BTW)
If you get a b18b1, you just take your distributor, injectors, alternator, wiring and swap them to the b1 and call it a day lol.
I'll wait for the "well my buddy says, or the I put a set of b1 cams in and picked up 20 horse" comments to arrive. Odds are if you see hp gains from swapping to b1 cams from a1 cams, its due to less mileage and wear on the "newer" cams.
Old Apr 6, 2011 | 04:42 AM
No problem. Thanks for clarifying. I just remember reading something about how one had more power than the other, so there had to be SOMETHING that was different between the two. Even if the difference is a bolt on, it's still something.
Thanks for clarifying though! This might help someone pic up a few horses if they're using a B18A mani and come across a B18B for cheap.
Old Apr 6, 2011 | 08:58 AM
yeah my dad is actually trying to source a b1 manifold for his b20 powered crx. He has an a1 manifold, but along with picking up some power it helps clean up the bay since the b1 manifold doesn't have all those damn vaccum lines.
Old Apr 6, 2011 | 09:11 AM
phaphon's Avatar
you should find out why your sleeves gave out maybe you had a boost spike
Old Apr 6, 2011 | 09:47 AM
protopro88's Avatar
How do I go about finding out how they cracked
Old Apr 6, 2011 | 09:58 AM
speedooo's Avatar
They both have 9.2:1 c/r but for some reason the pistons are labled differently.
2001 Integra Ls: 13020-P54-000
1992 Integra Ls: 13011-PR3-003
Old Apr 6, 2011 | 10:01 AM
phaphon's Avatar
honestly im not even sure i found out my wg was bad from when i took it back to go get it tune'd maybe someone can chime in and help you out
FrodeyEJ1
Mar 15, 2013 12:19 AM
AdrenalineAngel
Oct 31, 2012 09:22 PM
AdrenalineAngel
Oct 27, 2012 08:25 PM
Mr HYDE
Apr 10, 2004 06:20 PM
rocco
17
Jan 11, 2004 05:06 PM
