B18A/turbo smoking?
Old Jul 12, 2002 | 03:23 AM
D16Z6racing's Avatar
Default B18A/turbo smoking?
Just installed a fully built B18A with a Drag 2 kit into a 96 INT Special Edition. Once the car warms up, white smoke comes out of the exhaust. The motor without the turbo is fine, so were guessing something is wrong with the turbo. Any ideas on what it could be? Thanks.
P.S. - The turbo was just rebuilt by Turbotecnics and has 50 miles on it.
Old Jul 12, 2002 | 04:14 AM
MiraiZ's Avatar
Default Re: B18A/turbo smoking? (buster13)
I'd say that the head was not torqued down correctly.
or the head gasket isn't on correctly
[Modified by MiraiZ, 10:16 PM 7/12/2002]
Old Jul 12, 2002 | 04:33 AM
lsvtec101's Avatar
might be a oil seal in the turbo pull off the piping see if any oil flim is inside it.
Old Jul 12, 2002 | 04:39 AM
RGAZ's Avatar
New User
Water cooled center section? The bearing is not sealing and the turbo is leaking coolant into the intake charge. Pull the intake piping and look for evidence of coolant. Could also be oil leaking past seals.
More likley that you have a headgasket failure though. Do a compression check.
Randy
Old Jul 12, 2002 | 10:23 PM
KittyKat's Avatar
When'd you get a turbo? I didn't know you had a turbo kit for your car. Why didn't you tell me? hmmmm... Love you honey!!!! I'm not gonna give up one you.
Old Jul 12, 2002 | 10:47 PM
Default Re: B18A/turbo smoking? (KittyKat)
Did a few test today. A leak down was one. Motor is gonna get new valve seals and new piston rings. Pulling the head off tomarrow.
luv2boost
Jul 6, 2007 05:01 AM
kasso
Sep 8, 2005 12:05 PM
drift4food
Apr 8, 2005 05:07 PM
vteccivicracer03
Nov 26, 2003 11:01 AM
CivicNewbie
Jan 27, 2002 02:16 PM
