b18 turbo w/ stock injectors
can you run a t04e 57 trim with stock injectors on 5-10 psi?
lets say there is a moderate goal of 250 whp...what size injectors would you recommend and how much would stock injectors hurt those power goals?
Modified by idewson at 5:28 AM 2/3/2006
Re: b18 turbo w/ stock injectors (idewson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by idewson »</TD></TR><TR><TD CLASS="quote">can you run a t04e 57 trim with stock injectors on 5-10 psi?
Modified by idewson at 5:28 AM 2/3/2006</TD></TR></TABLE>
Assuming you're not running any kind of manifold pressure based fuel riser i.e. FMU, you won't be getting anywhere past 190-ish on stock injectors at 45-50psi at the rail.
