B18 turbo setup question
Old Aug 31, 2009 | 01:54 PM
Rob C's Avatar
Default B18 turbo setup question
Looking at doing a conversion on my B18 vtec... Do i need to change the pistons rods and uprate the head gasket? It has just had a head gasket change but would i need a upgraded one?
I will only be running low boost as it is just for a small project on my EG
Old Aug 31, 2009 | 01:58 PM
b20beast83's Avatar
Default Re: B18 turbo setup question
you will be fine with a good tune
Old Aug 31, 2009 | 02:03 PM
Rob C's Avatar
so i wont need to put a decompression plate in or anything to lower the compression?
Old Aug 31, 2009 | 02:42 PM
b20beast83's Avatar
you can make 350whp with a good tune
Old Sep 1, 2009 | 05:29 AM
Rob C's Avatar
and i also believe i will need to change my map sensor and injectors, will rc 440's be ok with a hondata s300 ecu?
Old Sep 1, 2009 | 05:42 AM
b20beast83's Avatar
if you plan to run under 10 psi, stock map is fine
also you can use dsm injectors/ they are 440cc and can be had for cheap
i also like eCtune management. ectune.com
but use what your tuner recommends.
Old Sep 1, 2009 | 05:47 AM
Rob C's Avatar
dsm injectors? im lost lol
Old Sep 1, 2009 | 04:33 PM
b20beast83's Avatar
^ evo injectors ect
Old Sep 2, 2009 | 02:21 AM
Rob C's Avatar
oh cool cool... but i do have to get a new ecu dont i? like a hondata or something similar?
Old Sep 2, 2009 | 02:43 AM
Bailhatch's Avatar
Many of the managments you can use will just add on to the stock ECU. Call the shp and ask them what they would tune your car with. Then come tell us what they prefer to use and we'll tell you if it sucks or not
Old Sep 3, 2009 | 03:08 PM
Rob C's Avatar
I have spoken to a guy at my local tuning shop and he recommended a hondata ecu... is it true that i can download a map for the s300 via usb just to get the car running? and then take it to the shop to get it mapped up correctly
Old Sep 3, 2009 | 06:23 PM
Bailhatch's Avatar
good, if that's what he sells and tunes, and he has a good reputation, go with that. As far as the basemap thing, I don't know, never played with that system. Your tuner should be able to set you up with something to start it with anyhow.
Old Sep 4, 2009 | 06:20 AM
Rob C's Avatar
once i have everything all fitted and ready would the car run before i change the ecu or would it not run at all untill i change the ecu?
Fnix
May 17, 2012 03:04 PM
spoolin turbo s
Sep 5, 2009 07:02 AM
96electronH
Engine Management and Tuning
11
Aug 26, 2009 09:01 PM
FOrSfEd
May 10, 2002 07:20 AM
TurboSedan
Feb 2, 2002 08:26 AM
