B16a2 Questions
Old Nov 29, 2006 | 07:24 AM
RYan McG.'s Avatar
Default B16a2 Questions
I own a 2000 si w/ 42k miles on it. This is my first build that I will be doing and Im not exactly sure of what to expect in the end?
B16a2 stock bore
Sp log manifold
tial 38mm w/g
skunk2 exaust
sp down pipe
jrc intercooler
sc61 52e .70 a/r ported S housing
550 cc (upgrade needed?)
Arp head studs
Cp 9:1 pistons
eagle h beam rods
cometic head gasket
acl bearing kit
and built drivetrain w/o lsd
what can I expect number wise after professional tuning on 100 octane with a decent amount of boost? What is a decent amount of boost to run? and would it benifit me to get GSR cams? w/ slicks and good driving what is an attainable et.?
Old Nov 29, 2006 | 07:50 AM
b18sihatch's Avatar
Default Re: B16a2 Questions (RYan McG.)
injectors def need to be upgraded for more power gains. those will limit you 750cc would be nice.
as for power 300-350 depending on the boost levels you are looking to push
Old Nov 29, 2006 | 08:32 AM
RYan McG.'s Avatar
I was to run say 16 psi? what kind of # then?
also are gsr cams a good thing to look into? advantages?
Old Nov 29, 2006 | 08:37 AM
b18sihatch's Avatar
upper 300s lower 400s maybe more
Old Dec 6, 2006 | 04:26 AM
RevTek 6's Avatar
Default Re: B16a2 Questions (b18sihatch)
300 to 400
Old Dec 6, 2006 | 06:09 AM
rmcdaniels's Avatar
Yes, get GSR cams, you'll make more power and you can usually find a set for $50-$75 in good condition.
Jbur074
17
Dec 25, 2007 06:06 PM
watacanga
Oct 31, 2007 01:51 PM
EJ8 GSR-T
Oct 26, 2006 01:21 PM
EK4Vti
May 26, 2006 04:46 PM
sluggo
Aug 6, 2005 04:41 PM
