b16a turbo problem
Old Apr 23, 2014 | 04:49 AM
sick tune-BH's Avatar
Default b16a turbo problem
info first:
2000 civic si
b16a engine
6266 t3 v-band presicion turbo
38mm wastegate
hondata 4bar map sensor
snow stage 1 water/meth system
mac boost by gear system
victor x intake manifold
id 1000 fuel injectors
,,,thats all info u need i think need more info ill post
so i reached a dead end and dont know what causing the sh** im having.
when i drive the car and its about to get boost rpm drops all sudden engine keeps running but not speeding any further no matter how much i increase throttle,,i was having this issue few months ago but it was coming rarely and the issue go after few mins of driving i thot it was the water/meth system getting the engine to cold or sum so i never gave it much of attention..three days ago the issue happened again and not to stop its happening in every gear,,if engine cold or hot,,throttling slow or fast,,no matter what i do its not stopping,,,so i done an air leak test,,check the map sensor,,,check the wastgate,,injectors,,boost by gear system,,turbo,,all is good i even thot of shutting the meth water system but there is no need since meth activation point @(5200rpm) when im even not reaching 2500rpm in every gear ...
Old Apr 23, 2014 | 04:59 AM
ferio-ichi3's Avatar
Ferio Wdm Edition
Default Re: b16a turbo problem
Was everything working before the boost?
Old Apr 23, 2014 | 05:08 AM
yea and it was working fine with boost to
Old Apr 23, 2014 | 06:27 AM
LTCxD2B's Avatar
Check the parameters in ur tuning software
Old Apr 24, 2014 | 01:35 PM
So it turned out to be the tps one of its wires was cut off cuz heat I quess! After i changed the socket tried to adjust it and turned out to be the sonsor is faulty it was only giving a max 20% reading I changed it and now car is working so smooth and I can ride in the hardcore way again,, hope this help sum1 that well hv this issue in future.. ohh but w8 I hv a question whay the hell check engine never lighted on,, ecu havent giving me error codes 2 !!.
Old Apr 24, 2014 | 04:22 PM
TheShodan's Avatar
Moderator
Good going.. Way to use a nice "low tech" approach.
Old Apr 25, 2014 | 01:17 AM
wantboost's Avatar
Who is Mr Robot?
This might sound stupid but the bulb for the CEL in the cluster can be blown. I've seen this happen many times.
Also if it was only a tps issue and the voltage the ecu saw never went out of range then it wouldn't throw a cel in the first place.
Old Apr 25, 2014 | 02:07 AM
Old Apr 25, 2014 | 02:28 AM
cel works for 5sec first i turn ignition on and i have removed fan switch to check if its working and it was working fine,,,i c what r u getting 2,,you can c it with datalog but still they should make it give a cel when a sensor that important is not giving a good reading,,just an opinion.
Old Apr 25, 2014 | 03:58 AM
wantboost's Avatar
Who is Mr Robot?
to the ecu the reading was fine. hence no code.
if the voltage went out of its 0-5vdc range or didn't get any voltage at all then and only then would the ecu throw a code.
what engine management are you using?
Old Apr 25, 2014 | 05:46 AM
m4xwellmurd3r's Avatar
Yeah I recently found out the tps I thought was ok os faulty. Plugged in s300 and found put it maxes at 63% and the scaling from 0-63 was jittery and glitchy as hell. Swapped throttle bodies and now its good. (Other throttle body has the factory screws, I didnt wanna cut them)
Old Apr 25, 2014 | 01:33 PM
s300 in a p91 ecu
Old Apr 25, 2014 | 01:42 PM
my throttle body works fine but im still thinking to change it with blox 70mm,,now im running with what we call here type-r dont know what is the right naming to it lol..
Old Apr 28, 2014 | 06:44 AM
my new tps gone bad again that fast!! the only thing im thinking is the meth/water mixture,,can that be the cause guys? if so is there a solution to it.
CarbonEG43
Engine Management and Tuning
15
May 31, 2013 03:58 PM
kielcivic
Jul 20, 2011 05:45 AM
alpha
Dec 10, 2005 09:50 PM
crxdelsolvtec
Jan 17, 2005 09:21 AM
Jradrebel
Oct 13, 2004 02:12 PM
