b16a turbo problem
info first:
2000 civic si b16a engine 6266 t3 v-band presicion turbo 38mm wastegate hondata 4bar map sensor snow stage 1 water/meth system mac boost by gear system victor x intake manifold id 1000 fuel injectors ,,,thats all info u need i think need more info ill post so i reached a dead end and dont know what causing the sh** im having. when i drive the car and its about to get boost rpm drops all sudden engine keeps running but not speeding any further no matter how much i increase throttle,,i was having this issue few months ago but it was coming rarely and the issue go after few mins of driving i thot it was the water/meth system getting the engine to cold or sum so i never gave it much of attention..three days ago the issue happened again and not to stop its happening in every gear,,if engine cold or hot,,throttling slow or fast,,no matter what i do its not stopping,,,so i done an air leak test,,check the map sensor,,,check the wastgate,,injectors,,boost by gear system,,turbo,,all is good i even thot of shutting the meth water system but there is no need since meth activation point @(5200rpm) when im even not reaching 2500rpm in every gear :mad: ... |
Re: b16a turbo problem
Was everything working before the boost?
yea and it was working fine with boost to
Check the parameters in ur tuning software
So it turned out to be the tps one of its wires was cut off cuz heat I quess! After i changed the socket tried to adjust it and turned out to be the sonsor is faulty it was only giving a max 20% reading I changed it and now car is working so smooth and I can ride in the hardcore way again,, hope this help sum1 that well hv this issue in future.. ohh but w8 I hv a question whay the hell check engine never lighted on,, ecu havent giving me error codes 2 !!.
Good going.. Way to use a nice "low tech" approach.
This might sound stupid but the bulb for the CEL in the cluster can be blown. I've seen this happen many times.
Also if it was only a tps issue and the voltage the ecu saw never went out of range then it wouldn't throw a cel in the first place. |
Originally Posted by TheShodan
(Post 49677628)
Originally Posted by wantboost
(Post 49678276)
to the ecu the reading was fine. hence no code.
if the voltage went out of its 0-5vdc range or didn't get any voltage at all then and only then would the ecu throw a code. what engine management are you using? |
Yeah I recently found out the tps I thought was ok os faulty. Plugged in s300 and found put it maxes at 63% and the scaling from 0-63 was jittery and glitchy as hell. Swapped throttle bodies and now its good. (Other throttle body has the factory screws, I didnt wanna cut them)
(Post 49678354)
Originally Posted by m4xwellmurd3r
(Post 49678471)
my new tps gone bad again that fast!! the only thing im thinking is the meth/water mixture,,can that be the cause guys? if so is there a solution to it.
