B16a t3/t04b problem!
Old Jan 27, 2009 | 08:53 AM
mc_yen's Avatar
Default B16a t3/t04b problem!
B16a (complete stock) on t3/t04b on Exedy Stage 2 clutch.
I'm having this problem that whenever i'm on boost, the rpm doesn't climb smooth especially in between 6000-8000rpm. I hit boost @ around 5300rpm but at around 6800rpm it will sorta get stuck, i continue to WOT it will climb to 7000rpm but it will start to misfire. When it start to misfire i'll have to change gear, therefore my opponent will pull in front.
Can anyone help? Could it be tuning problem? or Could it be the clutch slipping?
thanks!
Old Jan 27, 2009 | 08:56 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: B16a t3/t04b problem!
if it was the clutch, rpm's would increase and the car wouldnt accelerate. i would say you have an ign issue but cant be 100% on that.
Old Jan 27, 2009 | 09:07 AM
irishflame27's Avatar
sounds ignition related, what are you gapping your plugs to? when is the last time it was matienced?
Old Jan 27, 2009 | 09:16 AM
h2.4's Avatar
is your boost staying consistent, or creeping at higher rpm? whats your a/f ratio when it starts misfiring? maybe running lean, or having ign. probs like stated earlier. more info.
Old Jan 27, 2009 | 09:21 AM
tegman23's Avatar
What type or engine tuning are you using? What are your plug gaps?
Old Jan 27, 2009 | 09:32 AM
mc_yen's Avatar
Hi guys, million thanks for your input, I'm tuning with Autronic Sm2 Ecu.
My boost is consistent, no boost creep. I don't have any A/F ratio monitoring device inside my car to monitor..
I called my workshop, he mentioned that he needs to check the plug gap and he said my car is tuned rich. He might need to lean out a little and see how it goes. I'm also betting that it could be due ign issue..
Old Jan 27, 2009 | 11:58 AM
HiProfile's Avatar
Icon3 Re: B16a t3/t04b problem!
If its tuned a little lean or the plug gaps are too large (usually over .032"), you will get that sort of stuttering issue. Lean conditions do with via bad detonation, large plug gaps just don't fire. Overly-rich can also do that, as it also won't allow the plug to fire.
Not tuning a turbo Honda is about the worst thing you can do. Almost all other cars use MAF sensors, and don't need as much tuning. Hondas use speed-density systems with a MAP sensor, and *ANY* change can throw your AFR's and timing all out of whack.
Do not drive it hard at all until you get it tuned in some degree. Street tunes are still okay if you run conservative timing and a little rich.
XpL0d3r
Mar 15, 2012 12:10 PM
sleepercivic88
Apr 7, 2009 03:45 PM
TEGGRY
Mar 24, 2006 04:21 AM
kun3racer
Jul 7, 2004 03:25 PM
GSlowR
Jun 12, 2004 07:32 PM
