B16a setup?
Old Apr 12, 2010 | 12:18 PM
EHondaJDM's Avatar
Default B16a setup?
Got a b16a with a edelbrock fuel rail + regulator and a hondata intake spacer. What will I need to put a lil boost on this thing, im thinkin around 5-7 lbs
Old Apr 12, 2010 | 04:49 PM
iamthefollower's Avatar
Default Re: B16a setup?
a b series engine stock internals can handle around 300whp reliably.
Old Apr 12, 2010 | 04:53 PM
tuck1crx's Avatar
dont think in terms of boost. think in terms of HP. boost wont effect the motors inertial force, HP will. 300 is a safe number.
i should have saved ur money on the fuel rail. stock ones are good for 500+ HP
Old Apr 13, 2010 | 03:29 AM
EHondaJDM's Avatar
I got a deal on the fuel rail and it puts quite a nice touch on my motor so im not mad about it, so if I put 7ish lbs of boost I shouldn't have many problems? Would the same theory apply if I just put a 50 shot of juice on it?
Old Apr 13, 2010 | 03:35 AM
EHondaJDM's Avatar
Old Apr 13, 2010 | 06:33 AM
as he has stated, you can't really thnk of it in terms of psi. 7psi would be different on a little 50trim then what it will be on my t70 turbo, you have to look at what kind of HP you are wanting to be at.
So with that said, what is the HP range you are wanting to be at, and what turbo setup and such are you going to be using?
Old Apr 13, 2010 | 01:12 PM
EHondaJDM's Avatar
Im looking for like 230-250 whp. This is my daily driver so I don't need outrageous horses, I have a ls tranny so I figured the best thing to get the b16 out of low rpms is a turbo
Old Apr 13, 2010 | 01:54 PM
Ok, so you are wanting 230-250whp, so you could get a smaller turbo like a t3/t4e turbo or something of the sort and put about 9psi on it with a good tune and you will be good to go.
Old Apr 16, 2010 | 08:16 AM
EHondaJDM's Avatar
Think ill need injectors? Thanx btw
Old Apr 16, 2010 | 01:12 PM
you can get some DSM 450cc injectors for cheap, get on a DSM forum and go to the marketplace, I was on one and seen some Evo 550cc injectors going for $95, I paid $75 for my DSM 450's in my car. You just have to do a little modification to them but nothing big.
Old Apr 17, 2010 | 05:22 PM
EHondaJDM's Avatar
What kind of modifying? Will I need to hook up a resistor or are they the same voltage
Old Apr 17, 2010 | 10:06 PM
You will need to cut the inside of the injector out, where the little piece is sticking out. Not hard at all. If you are putting it in the 1995 integra that I see you have, then yes you would have to wire in a resistor box, but it doesn't take but a few minutes to do that either. Really simple.
Old Apr 17, 2010 | 11:28 PM
EHondaJDM's Avatar
where do I get a resistor and a wiring diagram to put it in?
Sorry new to boost
Old Apr 18, 2010 | 01:49 PM
you can go on phearable.net and get a resistor box and injectors or anything of that.. you could get a resistor box from an 88-91 Civic, or an early 90's integra. I don't know if 92 and 93 have them or not, they might. Let me see if I can find the wiring diagram and i will post it for you.
Old Apr 18, 2010 | 01:58 PM
ok here is what I used to do mine. You need an ohm meter to do it the easy way, or you can use a test light and stuff for the hard way, I didn't have an ohm meter so I had to use a test light and a paper clip and everything.. much much easier with a test light.
Old Apr 19, 2010 | 03:58 AM
EHondaJDM's Avatar
Kool man uve helped me tons, I work at a junkyard so I got like 30 civic/accord resistor boxes in a bucket, I mixed them cause they looked identical and someone told me they arnt. U have any idea?
Old Apr 19, 2010 | 05:52 AM
I used one off of a civic I know another guy that has used one from an accord, you won't be able to plug and play so you will have to wire the wires. But either one will work. Even if you have to get one from a DSM, i've heard people wiring them in.
Old Apr 20, 2010 | 03:45 PM
EHondaJDM's Avatar
Thanx again ill let u know how I make out
Old Apr 20, 2010 | 04:49 PM
EHondaJDM's Avatar
Old May 8, 2010 | 01:43 PM
EHondaJDM's Avatar
i just got a 98 eclipse gst in at my job, will the injectors work off it even though its obd2? Also I know I can use the spool but what else does this piece of junk have that I can use?
Old May 8, 2010 | 04:58 PM
EHondaJDM's Avatar
Bump
Old May 9, 2010 | 05:12 AM
EHondaJDM's Avatar
Anyone?
Old May 9, 2010 | 01:53 PM
EHondaJDM's Avatar
CAN I GET SOMETHIN PEOPLE??
Old May 9, 2010 | 08:28 PM
DC-2uned's Avatar
Not intending to be a d*** at all but, just judging by this statement/question you are no where near ready for a boosted car. Do a ton of research starting with the Turbo FAQ at the top of the forum, its a great read. Even if you are not the type to be mechanically inclined over time you can learn with lots of reading and some trial-n-error. As said earlier in the thread, shoot for hp goals or track times, not pounds of boost because that varies by turbo. If you are not intending to do the work, atleast research what parts you'll need and their cost online or local reliable sources, along with labor and dyno rates. So even if you have others do the install/tune you won't get ripped off $ wise and can make sure everything looks/works as it should.
Old May 10, 2010 | 01:41 PM
EHondaJDM's Avatar
its cool i just want to know what i can use, i still am reading up on everything im not just gonna throw it all on. u know i can use the 98 eclipse injectors on my 95 teg?
calboi
Apr 23, 2008 07:49 PM
92 white eg
11
Jul 23, 2007 02:40 PM
Ryceboi318
Jan 10, 2005 06:59 PM
Tomakit
Dec 10, 2001 10:43 AM
1sick4door
Dec 9, 2001 05:38 PM
