View Poll Results: Which Motor??
H22A
50.00%
B16A
50.00%
Voters: 46. You may not vote on this poll
B16A or a H22A??
Old Sep 25, 2010 | 10:42 PM
1LowSol's Avatar
Default B16A or a H22A??
Sup guys, So right now I have a Boosted D series in my Del Sol.. And it's pretty fun, But im getting ready to start a high performance class and I am going to be building a motor. I'm going to buy a new motor (H22A or B16A) And build it for boost. I know what the B16A's can do, But I really want to buy and build a H22A. I've heard that the H22A bottom ends are weak... and so on. I'm pretty sold on the H22A and will be Adding Pistons, Rods... And so on.
So basically what i need from you guys is your input.. I don't really know a whole lot about H22A motors.. So let me hear it guys. What motor would you guys go with? And why?
Thanks in Advance!
Old Sep 25, 2010 | 11:10 PM
rat city rex's Avatar
Default Re: B16A or a H22A??
F22 vtec, my reason is because its like a giant z6. And I think that they sound bitchen when they are done rite. Ive seen them make 300whp on stock bottom end, with just some head studs and boost!!!
Old Sep 26, 2010 | 08:33 AM
ShanghaiOC's Avatar
Between your 2 selections, I'd take the b16. But if you want a budget motor for boost, I'd take the F22! That head flows really well for boost & there are a few builds that lead the way on here
Old Sep 26, 2010 | 09:26 AM
dc2_dustin!'s Avatar
b20 can't beat the torque!
Old Sep 26, 2010 | 09:40 AM
sanman000719's Avatar
b18c1 just cant be beat as you can see from the top dawgs in this sport, and have been proven to make 500+ on stock everything
but i chose b16a because you dont have to spend the cash to go h2b
Old Sep 26, 2010 | 10:21 AM
tundra2000's Avatar
I got a b20 in my hatch and lovin it. I have a friend that has a b16 ( not sure what type ) but he tune it and was redlining a 9k and ran 14's on a non turbo motor and now he pulled it out to build it from bottom to top and plans on running more the 30psi.
But here is a site that tells you some more about the b16 and h22, the h22 weighs 200 pounds more then your normal motor so you will have to spend a little extra in stiffing up the suspension.
http://www.hondahookup.com/info/engine_swap_faq.php
Old Sep 26, 2010 | 10:53 AM
rudebwoy's Avatar
B series all the way, I know the K's are doing big things for the hondas but the B's are affordable and put the power down nice, with tons of support.
Old Sep 26, 2010 | 12:03 PM
reactiondc2's Avatar
why no b18 options?
Old Sep 26, 2010 | 12:09 PM
ronniedi's Avatar
go for the b16a2. that what i got. and people seem to love it espescially when its boost.
Old Sep 26, 2010 | 02:38 PM
worktoomuch's Avatar
I'd suggest an OBD 1 H22 and get the LSD trans ( M2B4). We put a peak boost kit on a friend's in his accord it makes 470 whp and 350 ft. lbs. (E85) Motor has head studs and a cometic head gasket.
Old Sep 26, 2010 | 02:46 PM
jdmH2Bek4's Avatar
How about b16 and h22 together H2B?
Old Sep 26, 2010 | 06:02 PM
KStuned's Avatar
Yessiree
Old Sep 28, 2010 | 09:43 AM
AccordtypeT's Avatar
H22a1!! You will have torque power and rev and it's not as heavy as some say, I have and h22 in a hacht its great!! Turbo you will have unlimited power
Old Sep 29, 2010 | 06:48 AM
m0uaman's Avatar
i had a H22 before but now have a b16...the h22 is going to give you headaches and cost more to swap in than a b16...you need custom engine harness, mounts, custom axles, the cable shift linkage...its just a hassle man...even after you get all that and you wanna boost then you have to get sleeves, and machining work just to be able to boost more than 5lbs...when i had my h22 hatch it was nice and strong...but going N/A cost alot more money then turbo and thats why i went to b series
Old Sep 29, 2010 | 03:33 PM
Stock cams and crank 25psi SC61 630 whp 558 ft. lbs of torque the numbers speak for themselves..........
Old Sep 30, 2010 | 05:07 AM
1988montecarlos's Avatar
im a noob. whats an H2B?
Old Oct 1, 2010 | 11:28 PM
DAN!!!'s Avatar
its an adapter plate that sandwiches between a H block and either a D or B series trans.
Old Oct 1, 2010 | 11:47 PM
kingofbattle909's Avatar
neither. f23a engine. it already has low comp; cost less and has a strong block. I think the cylinders are iron with a beefy girdle. ok lets see here... 1.6, 2.2, or 2.3? Why h2b? Its not all motor so longer gears would be key in a turbo build....right? (just my 2 cents)
Old Oct 2, 2010 | 12:49 PM
so an h2b is just an h series motor with a b or d series trans on it?
Old Oct 2, 2010 | 08:09 PM
jnv255's Avatar
H22>B16
Old Oct 2, 2010 | 09:37 PM
DAN!!!'s Avatar
yea
Old Oct 3, 2010 | 02:48 PM
reddcoupe's Avatar
A PROPERLY BUILT H22 ON BOOST BADDASSSSSSSSS
Old Oct 3, 2010 | 02:54 PM
jrsc_integra's Avatar
get a h23 block, h22 head, and a b series tranny!!
Old Oct 4, 2010 | 04:27 AM
blk_dc's Avatar
how much whp are you lookin to get? I would go with beastly boosted h22 for all out drag, or boosted b16 for autox/DD
Old Oct 4, 2010 | 05:50 AM
jdmcivicracer89's Avatar
yea srry but ur way off on the weights of theses motors. it been beat to death on threads comparing the h22 weight to the b16.. ENJOY
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/settle-h22-vs-b-series-weight-arguement-i-bring-you-pics-684550/
