b16a 150psi compression test
Old Feb 20, 2016 | 11:57 PM
b16a971's Avatar
Default b16a 150psi compression test
Hi. I have a stock b16a i want to turbo but my compression test results were 150 psi on all cylinders
Should i turbo this motor? Is it safe? It runs good and doesnt burn oil
My power goal would be around 280hp
thanks
Old Feb 21, 2016 | 02:52 AM
VegaS10's Avatar
Default Re: b16a 150psi compression test
That's on the low end of compression numbers.
Did you have the engine warmed up and the throttle body open when doing the test?
Old Feb 21, 2016 | 08:35 AM
b16a971's Avatar
I thought it was supposed to be on a cold engine? And yes it was on throttle open. Tried it with close throttle too but it reads the same
Il try to do it on a warm engine later today.
My vacuum reads 20in hg warm engine on idle by the way
Would a valve adjustment fix it?
Thanks
Old Feb 21, 2016 | 09:26 AM
VegaS10's Avatar
The engine needs to be warmed up to operating temperature.
Valve adjustment may help, but it would be minor.
Old Feb 21, 2016 | 11:12 AM
b16a971's Avatar
Can i still boost it? Looking for 280hp or a little less. Engine runs good and doesnt burn oil.
The compression by the way is spot on the same on all cylinders
Thanks again
Old Feb 21, 2016 | 03:09 PM
NotARaCist's Avatar
I never narc'd on nobody!
As long as you're within the service limits (you are), and the cylinders are all within 10% of each other, and the engine is properly taken care of, (and the turbo setup is done properly, with a good turbo and a proper tune) you'll be fine. Disco potato and go to town.
Old Feb 21, 2016 | 06:43 PM
b16a971's Avatar
Ok good to hear that. What do you mean by disco potato and go to town?
Thanks for the reply
Old Feb 21, 2016 | 06:56 PM
NotARaCist's Avatar
The Disco Potato is a certain turbo that would be good for your power goals, and has been proven many times in the past. They're also relatively easy to find.
Old Feb 21, 2016 | 10:05 PM
b16a971's Avatar
Ok will look into that but i already have a t3t4 garret 50 trim
thanks
rmrider12522
Mar 1, 2014 08:16 AM
umair
Dec 7, 2009 10:37 AM
gen2teggy
May 21, 2006 12:07 PM
INTEGRAGATED
Jan 30, 2004 05:37 AM
mugenracer
May 21, 2002 02:35 PM
