b16a low compression?
Old May 21, 2006 | 03:22 AM
gen2teggy's Avatar
Default b16a low compression?
i did a compression test and its was
150 150 150 150
my friend has the same engine and its
190
is that normal?
if its not...how do i fix it?
Old May 21, 2006 | 03:26 AM
bks84's Avatar
Loved
they are the same all across the board, so its probably due to wear/tear/age on the engine.
are you sure you did the test properly? did you have the TB open (wot)?
Call honda or buy a helms for a B16 equipped car and find out what the service limit is for the compression test, but overall make sure you did it right
The only way to fix a low compression reading is to rebuilt the engine. more then likely the rings or valve seals arent working right. It could also mean it needs a valve job.
Old May 21, 2006 | 12:07 PM
95 integra's Avatar
Default Re: (4sd4dr)
150 is about shot, but then again, so are most 17 year old motors. It had 70k put on it in japan, then it sat for 10 years (by the sea where salt ate away at it), finally imported to the US where its been in 3-4 cars totalling 150k. Yep, its about time for a rebuild. Seriously though, just like 4sd4dr said, you need to double check that you did the compression check right because generally there will be more variance then that if its shot.
B16A Hatchback
Aug 22, 2008 09:25 PM
TylerH
Mar 15, 2006 11:16 AM
Greenery18
Jul 6, 2004 08:29 AM
Metal_SOL
Aug 9, 2002 12:05 AM
