b16 vs gsr cams
Old Apr 11, 2005 | 08:37 PM
95GSRTT
Guest
Posts: n/a
Default b16 vs gsr cams
Yes I know this has been talked about alot, but I promise its a slightly different question
For my turbo setup im looking for 450+ whp and revving to about 8500 on ITR valvtrain and supertech valves.
Now my question is which cams will be able to flow the best up to 8500 rpms, and would switching to gsr cams net more than say 5 whp?
I can get a pair for a decent price, but want to make sure its really worth the price. Thanks
Old Apr 11, 2005 | 08:55 PM
project dc2's Avatar
Default Re: b16 vs gsr cams (95GSRTT)
gsr cams are better than B16 you can find a 20-30 WHP increase by using ITR"s
Old Apr 11, 2005 | 09:00 PM
95GSRTT
Guest
Posts: n/a
Default Re: b16 vs gsr cams (project dc2)
well are they better for more of a mid to lower power or will they make more power up top also?
Old Apr 12, 2005 | 06:09 AM
95GSRTT
Guest
Posts: n/a
bump for an answer of the actual question at hand
Old Apr 12, 2005 | 09:01 AM
deftones0817's Avatar
im running ctr cams in my car and i tell you what ask anyone that thing moves. I think ctr/itr are the way to go. Gsr are ok too and are cheaper.
Old Apr 12, 2005 | 09:33 AM
95GSRTT
Guest
Posts: n/a
Default Re: b16 vs gsr cams (deftones0817)
ya i know all about how much more the itr cams will make, but i dont really want to spend another 250 on itr/ctr cams. Only reason I would switch to gsr cams from b16 cams is b/c i can get a pretty good deal on them.
So pretty much im wondering if the b16 or gsr cams will be able to hold power the longest up top? and by how much more the gsr cams really make over the b16s in general?
Old Apr 12, 2005 | 09:48 AM
4-banging's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95GSRTT &raquo;</TD></TR><TR><TD CLASS="quote">ya i know all about how much more the itr cams will make, but i dont really want to spend another 250 on itr/ctr cams. Only reason I would switch to gsr cams from b16 cams is b/c i can get a pretty good deal on them.
So pretty much im wondering if the b16 or gsr cams will be able to hold power the longest up top? and by how much more the gsr cams really make over the b16s in general?</TD></TR></TABLE>
spend the extra cash and tell us. . .I'm sure you won't be disappointed
Old Apr 13, 2005 | 06:54 AM
95GSRTT
Guest
Posts: n/a
Default Re: b16 vs gsr cams (4-banging)
bump it up for an answer
Old Apr 13, 2005 | 11:13 AM
integlspwr2k's Avatar
i herd the automatic b16 cams are even better then the GSR ones.
Old Apr 13, 2005 | 12:24 PM
hpfsi's Avatar
Default Re: b16 vs gsr cams (integlspwr2k)
I've never heard that... gsr cams have a bit more lift on the intake side and more duration on both sides than b16a cams which seems to yield gains over stock without changing the characteristics of the motor in terms of powerband etc... itr's have even more lift and duration and push the sweet spot a bit further up the rpms depending on your engine's specifics. Any upgrade over b16's should be an improvement, I went with gsr's because they are readily affordable/available and have good hp-per-$ yields since I don't plan on taking this motor over 8500rpm.
Civic Si(1999 Spec)
Int-265 dur. / 10.5mm lift
Exh-267 dur. / 9.6mm lift
Integra GS-R
Int-274 dur. / 10.7mm lift
Exh-276 dur. / 9.6mm lift
Civic Type-R And Integra Type-R(Integra Type R 2000/01 Spec)
Int-278 dur. / 11.5mm lift (97-98 spec = 3 deg less duration)
Exh-280 dur. / 10.5mm lift
Old Apr 13, 2005 | 12:36 PM
Default Re: b16 vs gsr cams (hpfsi)
its one of those things were its kept hush hush and not like u come across alot of automatic b16 cams anyways..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hpfsi &raquo;</TD></TR><TR><TD CLASS="quote">I've never heard that... gsr cams have a bit more lift on the intake side and more duration on both sides than b16a cams which seems to yield gains over stock without changing the characteristics of the motor in terms of powerband etc... itr's have even more lift and duration and push the sweet spot a bit further up the rpms depending on your engine's specifics. Any upgrade over b16's should be an improvement, I went with gsr's because they are readily affordable/available and have good hp-per-$ yields since I don't plan on taking this motor over 8500rpm.
Civic Si(1999 Spec)
Integra GS-R
Exh-280 dur. / 10.5mm lift </TD></TR></TABLE>
Old Apr 13, 2005 | 01:07 PM
hpfsi's Avatar
dude don't let the word out about the auto b16 cams... we have to maintain an edge somehow
EvanM1
18
Jun 9, 2010 09:41 PM
staindgd
Jan 28, 2008 06:28 PM
blackcrx16
Jun 19, 2007 10:39 AM
CRX11Z
Apr 12, 2007 02:05 AM
ShAAdiiiNG
18
Jan 10, 2003 05:18 PM
