B16 vs B18 differences
Old Oct 2, 2009 | 10:36 AM
IntegraTypeR's Avatar
Default B16 vs B18 differences
Hey guys i have a turboed B16a and now am going the B18c route....wanted to know what are the parts that these engine share or differ from.
Similar parts:
1- head gasket?
2- oil pan?
3- Distributor?
4- Spark plug wires?
5- flywheel/clutch?
Different parts:
1- timing belt?
2- oil pick up?
in general i need hints and points on where/what i need to change to make the swap work? my b16 was perfect running until some incident happened and now am going the B18 route....i will re-use the B16 head and B16 (S4C) tranny and Exedy twin plate i have on my B16 setup. what do i look to get to get this B18 work without any missing parts?
In general what i can i re-use and not re-use?
Old Oct 2, 2009 | 11:13 AM
komat's Avatar
Default Re: B16 vs B18 differences
so you are doing a lsvtec or gsr?
Old Oct 2, 2009 | 11:15 AM
GSR
Old Oct 4, 2009 | 02:43 AM
any help?
Old Oct 5, 2009 | 04:42 AM
bump
Old Oct 5, 2009 | 04:59 AM
dephtone's Avatar
Similar parts:
1- head gasket? Yes
2- oil pan? Yes
3- Distributor? NO, it has a different mounting ears.
4- Spark plug wires? YES
5- flywheel/clutch? This depends on the trans. If you use the same trans as on the b16, then it should be the same, if using a GSR, you will have to check the size of the splines.
Different parts:
1- timing belt? Same as b16
2- oil pick up?
I personally would not reuse the headgasket, or timing belt. You can reuse everything else though if it is in good working order.
Old Oct 5, 2009 | 05:12 AM
Originally Posted by dephtone
Similar parts:
1- head gasket? Yes
2- oil pan? Yes
Different parts:
2- oil pick up?
i thought the B18c timing belt has more teeth and longer because of the b18c long block is taller? i even thought all B series dist will work depending if it meets the OBD requirement
am definatly getting a new headgsket and timing belt!
Old Oct 5, 2009 | 05:38 AM
dephtone's Avatar
Yes you are right about the distributor, they are the same, that was my fault.
I will have to double check on the timing belt, I swear mines from a GSR but I will have to look again. If so, I got the wrong one lol.
Old Oct 5, 2009 | 05:43 AM
GEN2 LS's Avatar
Loved
Similar parts:
1- head gasket? Yes
2- oil pan? Yes
Different parts:
2- oil pick up?
i'm pretty sure a b16 oil pan will not work on a gsr block, because of the girdle.
Old Oct 5, 2009 | 06:01 AM
boosted k20's Avatar
B16 timing belt and GSR belts are different. B16's are shorter. And you can use the same distributor.
Old Oct 5, 2009 | 06:16 AM
Bseriescivic5's Avatar
Good deal of bad information in this thread already. Here is what you need to know:
-Oil pan MUST BE GSR, the girdle will not allow you to use a b16a oil pan
-Dizzy is same, guts are all interchangeable, just make sure it was a VTEC dizzy to start with and meet your specific OBD1, OBD2, OBD0 requirements
- Timing belt MUST BE GSR, block is taller and is longer than the b16a
- Trans, clutch, ect combo is fine all b-seres are the same...Hydro to hydro, cable to cable, but they all will bolt up fine to the block, just on you if you are doing a cable system or hydrolic.
-HG is the same, 81mm bore on both b16a and GSR, but obvioulsy get a new one.
-Water pump is same, I THINK, but oil pump may be different, I cant remember
-Timing belt tensioner is same
Hope this helps.
Old Oct 5, 2009 | 09:41 PM
Hope this helps.
i used to have a GSR oil pump on my b16 and was using a b16 timing belt, so i think the oil pumps number of teeth is the same on both b16a and b18c. i belive the waterpump differs maybe
Old Oct 6, 2009 | 05:31 AM
Hmmm, well maybe that has something to do with which oil pump and water pump you use, im not sure if the teeth vary between pumps, but I know I got a b16a belt on accidnet and my builder had to send back to get the GSR belt. Reguardless of anything, the GSR block is taller and it just makes sense to use the belt from the shortblock you have in the car.
jasoncmps@gmail.com
Apr 14, 2010 06:15 AM
Too_slow_eg
Jan 25, 2010 10:07 PM
construct1
Nov 13, 2008 12:40 PM
hi-Powered
Jan 18, 2005 08:15 AM
