b16 jackson power?
Old Jan 22, 2008 | 11:11 AM
MeGotRoundEye's Avatar
Default b16 jackson power?
how much hp and tq would a b16 (stock) with a jackson supercharger put down? and what would the 1/8th mile times look like in a 92-95 civic hb?
thanks
Old Jan 22, 2008 | 12:21 PM
Schister66's Avatar
Man U FTW
Default Re: b16 jackson power? (MeGotRoundEye)
Back on topic...
Most JRSC'd setups are limited by two factors:
1. The JRSC can only spin so fast due to gear ratio on the pullies
2. The JRSC is not intercooled and higher IATs require higher octane fuels.
Power output is going to be determined by a combination of supporting mods, which pulley you're running, fuel grade, tuning and static compression ratio. Similarly, there are a lot of variables with 1/4 mile times. Bottom line, the JRSC wont get you over 300whp...determine your times from that.
BTW, a turbo setup is a much better option
Old Jan 23, 2008 | 04:17 AM
Default Re: b16 jackson power? (Schister66)
how does the gear ratio affect the jackson? i though it was full time power. does this mean that longer gears would help?
Old Jan 23, 2008 | 04:37 AM
Schister66's Avatar
Man U FTW
The gear ratio i was speaking of, was that between the crank pulley and the supercharger pulley. It has nothing to do with the gearing in the transmission. I feel that, unless you're getting a stellar deal on this JRSC, a turbo setup would be a much better option. B16's need something that can keep up through redline and continue making power along the way. Look at this graph of a JRSC overlayed with a simple Drag kit:
https://honda-tech.com/zerothread?id=688120
Old Jan 23, 2008 | 05:36 AM
Default Re: (Schister66)
im just scared or the idea of tuning a turbo car. i have alot to learn. lol. plus this would be my only car. but the jackson is over priced so i will think about it. is the compress of a b16 safe for a turbo set up running around 6lbs?
Old Jan 23, 2008 | 08:13 AM
kyle-Lst's Avatar
Default Re: (MeGotRoundEye)
as long as you tune it and dont abuse the **** out of it 8 to 10 is def safe if your motor is in good shape
Old Jan 23, 2008 | 08:32 AM
Default Re: (kyle-Lst)
hmm... what would be the ideal set up for my turbo b16 set up?
Old Jan 23, 2008 | 09:09 AM
Schister66's Avatar
Man U FTW
Boost pressure alone does not mean anything. I tell people this all the time, yet everyone still limits themselves in terms of PSI.
The static compression of the B16 is a little high; however, that merely limits the amount of power you can make on a certain fuel grade. For example, i boosted my stock internal GSR on 91 octane and made 315whp. That's more than any JRSC will net...
Old Jan 23, 2008 | 10:20 AM
im just looking for around maybe 250whp is that possible with the jackson?
Old Jan 23, 2008 | 12:40 PM
Schister66's Avatar
Man U FTW
yes, but with a properly sized turbo setup, you would make more power all around than a JRSC
Old Jan 25, 2008 | 04:20 AM
ok so its tax time.... what would be the ideal turbo setup for me to look into? could i get away with spending a grand?
Old Jan 25, 2008 | 04:53 AM
Clayton's Avatar
H-T Administrator
25 Year Member
No, realistically $1000 will not buy you all the necessary parts you need to have a safe reliable turbo setup. Having said that, you might be able to piece together a system for the much money, but it will never be reliable. Have a look through the sponsor FS sections here on H-T and talk to different vendors about your wants/needs and then go from there. I really hate to come off as a jerk, but $1000 won't buy much of anything when it comes to a well put together setup
Old Jan 25, 2008 | 05:13 AM
Default Re: (Clayton)
i was afraid of that. if im going to do it i want it to be done right. i will continue to save money and learn as much as i can. this turbo stuff isnt something you can jump into blindly if your as broke as me. lol. what if i was to practice on my d15b7 with junk yard parts? (hf mani, eclipse intercooler, ect...) what parts would be best to use?
Old Jan 25, 2008 | 05:14 AM
how cheap could i come out with this set up for now?
Old Jan 29, 2008 | 03:34 PM
93CX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MeGotRoundEye &raquo;</TD></TR><TR><TD CLASS="quote">i was afraid of that. if im going to do it i want it to be done right. i will continue to save money and learn as much as i can. this turbo stuff isnt something you can jump into blindly if your as broke as me. lol. what if i was to practice on my d15b7 with junk yard parts? (hf mani, eclipse intercooler, ect...) what parts would be best to use? </TD></TR></TABLE>
That sounds like a great idea I learned so much from my first turbo setup, even though all the parts were junk. Plus, a D15B7 with a turbo setup will net you close to what you could make with a JRSC'd B16.
Old Jan 29, 2008 | 04:12 PM
B16A1-EF9's Avatar
i have an ls/vtec with 12.5:1 compression using b16a pistons and a cut head. the build started as all-motor, for that reason i have skunk2 stage 2 cams in there now.
i then got a jackson for really cheap....so i decided to through it on.
i run a b20 crank pulley using a b16 kit, which gives me 10 psi. the combo i got so far only gave me 235 to the wheels with no water injection and 91 pump gas. it makes about 150 tq at the wheels at about 2500 rpm and it keeps making power to 9500 rpm. the peak was at 8900 i think because of the cams.
i will be trying out ITR cams which will give me less overlap, i think they will make more power...if the motor lasts that long lol
Old Feb 4, 2008 | 07:04 AM
Default Re: (93CX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93CX &raquo;</TD></TR><TR><TD CLASS="quote">
That sounds like a great idea I learned so much from my first turbo setup, even though all the parts were junk. Plus, a D15B7 with a turbo setup will net you close to what you could make with a JRSC'd B16. </TD></TR></TABLE>
thanks i think that what i will do for now. id love to see that d15b7 blow up anyway before i swap. what the junk yard parts list? and what other cheap goodies do you guys know of?
porofek
Nov 3, 2016 01:50 AM
lsone
Nov 26, 2010 10:17 AM
StreetEG
Apr 24, 2006 05:36 AM
112480
Dec 14, 2001 07:09 AM
