b16 head question
Old Apr 15, 2005 | 10:02 PM
DRIVENRacing's Avatar
Default b16 head question
my question is this..i have a built GSR bottom end. 9.7:1 compression wiseco pistons, crower rods, STR block guard. bored to 81.5mm. there is a fully built b16 head in the shop that is not being used. i am concidering putting that head on my GSR block. the head is fully built with hardened race valves, valve springs, ratainers, guides and is ported and polished with a port matched type R intake manifold. i think the b16 would lower my compression a bit which would allow me to run some more boost do you guys suggest putting this built head on (wana rev to about 9k rpm) or just stick with the stock GSR head. also i have a 1,2 and 5 LS gear in my GSR tranny ( 3 and 4 are gsr ) i am going to be running 15psi daily with neptune and a t3/60-1. going for 400whp on a dynojet. any input is helpfull. thanks alot
Adam
Old Apr 15, 2005 | 10:38 PM
SSBPGSR's Avatar
Default Re: b16 head question (adSPEED)
i posted from a friends house, forgot to mention i will be using stock GSR cams in this b16 head. what compression ratio am i looking at with 9.7:1 pistons with the b16 head?
Old Apr 16, 2005 | 12:14 AM
*Boostwerks*'s Avatar
I think the compression ratio would be around 9:1 if I'm correct, and yes I would reccomend using the head.
Old Apr 16, 2005 | 02:37 AM
Y2KCivicSiR's Avatar
Default Re: b16 head question (SSBPGSR)
I hear nothing but good things about GSR botton end wit a B16 head....also known as "the poor mans Type R" where im from. I'd definetly recomend also
Old Apr 16, 2005 | 04:37 AM
SSBPGSR's Avatar
Default Re: b16 head question (Y2KCivicSiR)
sweet thanks, i look at it as an opportunity to run more boost
408EJ1
16
Jan 8, 2014 03:23 PM
Drew17th
Oct 11, 2006 10:18 AM
EFin' Kyle
Jul 26, 2004 10:09 PM
CBR
Aug 19, 2002 07:18 AM
Tyson Ballou
Dec 26, 2001 06:17 PM
