B16 civic with jrsc
Old Aug 24, 2012 | 06:39 AM
98b16sc's Avatar
Default B16 civic with jrsc
I have a 98 civic with a b16 swap and its supercharged with a jrsc pusshing 12 pounds of boost. The car was tuned befor i bought it but only 236whp is that too low for 12psi. As far as i know the internals are stock.
Old Aug 24, 2012 | 06:42 AM
kyden's Avatar
Default Re: B16 civic with jrsc
i'm surprised it isn't blowing hot air at 12 psi. sounds ok to me.
Old Aug 24, 2012 | 06:47 AM
JuggerNaut-CTR's Avatar
Im surprised it made that much...supercharged b16's arent know to make all that great of power.
Old Aug 24, 2012 | 06:49 AM
jbpnoman's Avatar
Do you have a boost gauge hooked up verifying that 12PSI, or is that just what the previous owner told you? Those things generally max out around 10PSI.
5 minutes on Google says 230-250 on a hot install is about right.
Old Aug 24, 2012 | 09:39 PM
98b16sc's Avatar
Yes there is a boost gauge
Old Aug 24, 2012 | 09:45 PM
wantboost's Avatar
Who is Mr Robot?
thats normal... jrsc's don't make lots of power, and after 10psi without an intercooler you might as well be using a heat gun... they just pump gobs of hot air at that pressure level
Old Aug 25, 2012 | 08:51 PM
wunfstgsr's Avatar
Loved
Community Favorite
yup that's its down fall! even with the lht manifold @12psi i was getting power loss from heat soak! My new pro charger super charger has little to no heat soak. but that's actually good i made 230+hp with 6psi on a stock gsr with bolt ons.
Old Aug 25, 2012 | 10:00 PM
wantboost's Avatar
Who is Mr Robot?
I really want to do a budget street build with an ls/vtec with either an eaton m90 or m112 for ***** and giggles one day... just mount it down where the ac compressor should be (seen a number of setups this way) this gives you the ability to run a front mount... should make good power with a wicked power band
jsk8r57
Aug 14, 2009 11:37 AM
02 Civic SI 865
Feb 21, 2007 01:16 PM
Gonzo_SiR
Oct 22, 2003 07:00 AM
siis2fast
Jun 25, 2003 09:22 AM
keebler65
Jan 28, 2003 08:08 AM
