b16 boost need help
Old Apr 28, 2007 | 06:57 PM
scuffywin's Avatar
Default b16 boost need help
ok so i have a built b16 in a 91 civic pw0, turbo pistons sleeves every thing put about 1000 miles on motor before turbo was put on nothing was wrong , now after turbo put on i am having trouble, thought it was just a problem at 4,500(whichis where vtec was) bumped vtec up till 6 works fine until 6 when the motor hits vtec it just spits sputters and will not go past have to back off.........also at idle idles high and evac code to fix left a vacum port open and turned idle screw almost all the way in, gotta be a better fix......also it jumps hard whne trying to cruise at half throttle in any gear its either all or none as far as throttle.......als ojust 6 psi for now....ANY AND ALL HELP IS APPRECIATED... thnx
Old Apr 28, 2007 | 07:10 PM
doood's Avatar
been there done that
Default Re: b16 boost need help (scuffywin)
is it tuned?
Old Apr 28, 2007 | 07:21 PM
scuffywin's Avatar
Default Re: b16 boost need help (doood)
no no not yet you think that will solve all probs??? all i have is vafc right now no cam gears, but 450cc and 255fuel pumpfuel rail fpr and everything, also i was just told i might be my plug gap, i got new plugs and went 2 degrees cooler on a vpower ngk any suggestions
Old Apr 28, 2007 | 07:51 PM
doood's Avatar
get that thing tuned with real management before you blow it up
now that you mention it, what is your plug gap?
Old Apr 29, 2007 | 05:13 AM
scuffywin's Avatar
ok my spark plug gap is at 35 and so your saying not to run it nothing until what...i get "real engine management" which is what???? so do you think i can get it tuned for about 6psi off my field vafc for like a month or two and when i have the money get a p28 and hondata?? also anyone know whats required for obd0 to 1 i know new ecu and izzy o2 and is that it or will i have to change all sensors or what
Modified by scuffywin at 11:11 AM 4/29/2007
Old Apr 29, 2007 | 10:41 AM
scuffywin's Avatar
can n e one help me please
kauai96
Nov 19, 2008 06:51 AM
b00stedda
Oct 5, 2007 01:35 PM
DelSolB16Maryland
Jan 25, 2007 07:29 PM
EGP
Jul 29, 2005 02:36 AM
truckhigh
Jun 27, 2005 07:07 PM
