B16 or B18 for boost...
Old Aug 23, 2004 | 09:32 AM
  #26
silverb18's Avatar
Default Re: Wuts Better 2 Boost? (jman30513)
I would recommend a LS Turbo setup in a civic, that's what I'm doing
Old Aug 23, 2004 | 10:19 AM
  #27
JDMH22HATCH's Avatar
Default Re: Wuts Better 2 Boost? (silverb18)
Both motors are great, but in all reality the longetivity of the motor all depends on the tuning involved. That should be where you put your most focus. I run almost 15psi daily on a bone stock LS. But on the other hand we also made 276/183 with a bone stock b16 @ 7.5 psi. Both motors are great, just find out what you really want out of the car and then make a choice.
Old Aug 23, 2004 | 10:37 AM
  #28
blackeg's Avatar
Default Re: Wuts Better 2 Boost? (JDMH22HATCH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMH22HATCH &raquo;</TD></TR><TR><TD CLASS="quote">Both motors are great, but in all reality the longetivity of the motor all depends on the tuning involved. That should be where you put your most focus. I run almost 15psi daily on a bone stock LS. But on the other hand we also made 276/183 with a bone stock b16 @ 7.5 psi. Both motors are great, just find out what you really want out of the car and then make a choice.</TD></TR></TABLE>
what #'s are you putting down with your ls turbo??
Old Aug 23, 2004 | 10:41 AM
  #29
NLR808's Avatar
Default Re: Wuts Better 2 Boost? (blackeg)
Boosted sohc is the way to go but if you want to get into the 12's and 11's then a turbo B series is the way to go
Old Aug 23, 2004 | 10:47 AM
  #30
I'll be retuning very soon and getting some new numbers. My boost controller had a blown out o-ring and kept bleeding off boost. When I thought I was tuning at 12psi it really wasn't, and a pinch in my map vacuum messed with a lot of **** as well. I made 270/240 prolly somewhere around 9-10psi. But I'll be retuned with some definite numbers and some new goodies very soon
Old Aug 23, 2004 | 01:16 PM
  #31
EKlat_9
Guest
Posts: n/a
Default Re: Wuts Better 2 Boost? (94hatcheg04)
i'd choose a b18
Old Aug 23, 2004 | 01:29 PM
  #32
14bcoupe's Avatar
Default Re: Wuts Better 2 Boost? (EKlat_9)
i go with a b18, at least with it you always have the option of adding the vtec head
miamiboy91
24
Feb 4, 2009 06:38 PM
b18bc3po
Aug 13, 2008 04:52 AM
hotimportcrx
Jun 18, 2005 04:20 PM
ieatrice
Oct 20, 2004 11:10 AM
Monstuh4U
Oct 29, 2001 06:53 PM
