B0OM!
Old Nov 12, 2001 | 09:31 AM
turbopanda's Avatar
Default B0OM!
I was racing with a 2JZ-GTE powered Nissan Cefiro the other day.. and I couldn't quite keep up with him, so I upped the boost. To about 1.5 bar. I overtook him, but a few seconds later, I also killed a piston in my engine Lesson learnt - its a Civic. If you want to play with a 2JZ-GTE, then get a Supra.
Old Nov 12, 2001 | 09:46 AM
4dGSR at work's Avatar
Default Re: B0OM! (nathan's boosted civic)
im not too quick w/ the math but 1.5 bar??? 22psi?? about?
what kinda whp output is that??
sohc with a?????what is it a 20g??
Old Nov 12, 2001 | 10:08 AM
PROFILES2000's Avatar
Default Re: B0OM! (4dGSR at work)
22.05 psi (if u use 14.7 lbs= 1 bar) 21.75 psi (if u use 14.5 = 1 bar)
i have been told that 14.7 is 1 bar but some other say 14.5 but i am not boosting that high anyway so im straight
Old Nov 12, 2001 | 12:18 PM
Kevin's Avatar
They swapped a 2jz-gte into a cefiro when they can be had with rb26dett? You guys and your swaps
Old Nov 12, 2001 | 01:37 PM
Tomakit's Avatar
Default Re: B0OM! (5speedv6)
b18c1 time...
Tom
Old Nov 12, 2001 | 02:19 PM
Prelussion's Avatar
damn what kinda internals did you have to hold up under 22psi for at least a few seconds?
Old Nov 12, 2001 | 02:55 PM
GSRwBOOST's Avatar
Default Re: B0OM! (Prelussion)
"You do not know the power of the darkside!" - Darth Vader
"Consume you it will.. hmmmmm ?" - Yoda
HPfreak
Engine Management and Tuning
13
Mar 14, 2012 12:41 PM
tallblondkid
Feb 17, 2005 10:20 AM
FlatTire
Apr 29, 2004 01:27 PM
LS-T
Dec 13, 2001 06:32 AM
