b-series manifold for 14b or t25
does aaannnnybody know where i can get a manifold for a 14b or t25 to bolt up to my gsr??????? aaaany help is appreciated. thanks
Re: b-series manifold for 14b or t25 (Blake)
Correct. The HKS accepts standard T-25 footprint. The garrett made DSM T-25 has a completely different flange.
Re: b-series manifold for 14b or t25 (JalopySiR)
Just a little off topic, but a T25 will not work well in a GSR application. Unless of course you are running over 12psi.
We tested one in a GSR and lost boost upon vtec. Spools up quick but lags top end. Maybe we used the wrong trim?
Maybe someone else can verify this?
If this turbo is really bad on the top end then what can you do to help it pull to 7500 without loosing boost?
