Average Oil temp
Old Oct 1, 2002 | 12:43 PM
DeepSi's Avatar
Default Average Oil temp
What is the average oil temp after driving for an extended time?
the reason i ask is because i used jb weld to patch a hole on the inside of my oil pan where the welder missed. Will the jb weld withstand the heat inside the oil pan from the oil? i think jb weld goes up to only 300 degrees. would i be safe, i dont want a piece of the jb weld to melt and get sucked in the engine.
i saw this post, but will it hold for extended drives.
https://honda-tech.com/zerothread?id=274179
thanks in advance
-deepsi
[Modified by DeepSi, 1:47 PM 10/1/2002]
Old Oct 1, 2002 | 01:20 PM
Brian_92GSR's Avatar
New User
Default Re: Average Oil temp (DeepSi)
No, your oil is never going to get that hot.
Old Oct 1, 2002 | 02:15 PM
DeepSi's Avatar
Default Re: Average Oil temp (Brian_92GSR)
Just wanted to make sure.
Old Oct 1, 2002 | 04:16 PM
Xerxes's Avatar
New User
it might get hotter if you do a top speed run or drive on a road course (i know a guy who was NA and would see temps up to 280F on the track) but otherwise you should haev nothing to worry about
bjones6215
Sep 10, 2013 07:55 PM
vladd
Mar 26, 2009 11:35 AM
flipstar760
12
Dec 17, 2006 05:07 PM
hondaboy4life
Sep 29, 2006 08:01 AM
BoostedH23a1
Oct 24, 2002 07:56 AM
