wire horn to switch?
sup guys i just put on a sir steering wheel on my eh and i dont have a horn anymore. is there a way i can just wire it to a push type switch? if so how can i do it? thanks
Re: wire horn to switch? (GoT HaTcH)
im sure you can. i would think that you could simply take the existing horn wires, connect them to a switch of some kind, the push button one if you like, and it should work. just make sure it is grounded and the button is in a fairly easily accessable spot.
never seen it done, but good luck on it!!!
It's easy to hook up to a button of some sort. First you need a button. Run one wire from positive wire of the stock horn to your button (using wire taps or splice it), and another wire from you battery to your button. Mount the button somewhere and you're done. The horn is already grounded, so don't worry about grounding it.
integraXTC
08-04-2005 08:27 AM
FBP Si 2000
01-21-2003 09:24 AM
