AVC-R problem...
Old Jul 26, 2003 | 12:55 AM
Lei Siew Long's Avatar
Default AVC-R problem...
was at the track tonight and when i press the scramble button, the car would pretty much shut off temporarily, for about a tenth of a second or two, and the shift light from the hondata would come on and then it would pick up pace again.
the AVC-R is set in between 10-11 psi and when the sscramble feature is activated it is set for 12-13 psi.
i would appreciate some insight on this.
thank you.
Old Jul 26, 2003 | 11:55 AM
Default Re: AVC-R problem... (Hatch4urSnatch)
anyone come across the same problem?
Old Jul 26, 2003 | 03:49 PM
some help would be appreciated.
Old Jul 27, 2003 | 06:49 AM
FrcdFedGsr's Avatar
was it installed correctly? or tuned correctly? any malfunctions to the unit itself? you might wanna check back with the installer
Old Jul 29, 2003 | 02:24 PM
Default Re: AVC-R problem... (FrcdFedGsr)
installed and tuned correctly. running the AVC-R with a hondata stage 2B.
anyone?
Old Jul 29, 2003 | 02:42 PM
Mase's Avatar
sounds like the scramble feature isnt wired correctly
Old Jul 29, 2003 | 02:47 PM
Default Re: AVC-R problem... (Mase)
when i go to the ETC. screen on the AVC-R, where it displays whether the sensors and scramble button is functioning correctly, it shows that the scramble button is off when the button isn't pressed and on when the button is pressed.
so, the install of the scramble button seems to be okay.
Old Jul 29, 2003 | 03:16 PM
ekb18c's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatch4urSnatch &raquo;</TD></TR><TR><TD CLASS="quote">was at the track tonight and when i press the scramble button, the car would pretty much shut off temporarily, for about a tenth of a second or two, and the shift light from the hondata would come on and then it would pick up pace again.
thank you. </TD></TR></TABLE>
What map sensor do you have? If your on the stock map then it's going to happen because Hondata with stock map can only follow up to 11.3 psi.
Old Jul 29, 2003 | 03:20 PM
Default Re: AVC-R problem... (ekb18c)
GM 3 bar map sensor. so, i don't believe that would be the problem.
Old Aug 5, 2003 | 01:51 PM
ttt
Old Aug 9, 2003 | 07:02 PM
i've tried everything. anyone else have any ideas?
2000GSRT
Sep 11, 2004 09:03 AM
2000GSRT
Sep 8, 2004 12:35 PM
96SR-V
May 20, 2003 08:33 PM
