Can't set revs with Hondata button.
I have a Hondata S200 with boost and a P28 and I am unable to set the revs using the push button.
Every time I press the brake pedal, the check engine light stops flashing. It's supposed to flash thousands of revs and then hundreds of revs.
Anybody have any idea what the problem could be?
Re: Can't set revs with Hondata button. (Spunkster)
The way i set mine is with the car running. You press the red button one time. The check engine light will flash. Bring the revs to where you want to launch at. Once their there, hold it and press the break. There ya go.
Re: Can't set revs with Hondata button. (SpoolnG2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoolnG2 »</TD></TR><TR><TD CLASS="quote">did u try what i said ? or no</TD></TR></TABLE>
yes I have and it doesn't work either.
The only way I know to get rid of it is to reset all the revs back to the default, but that will most likey change my VTEC as well and throw off the tune.
Re: Can't set revs with Hondata button. (project dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project dc2 »</TD></TR><TR><TD CLASS="quote">i dont think your hondata has those options unless you paid for em. </TD></TR></TABLE>you know you might be right. I used to have the stage 3 and had all of those features and now they don't seem to work.
