AUTOMETER OIL PRESS. T FITTING...HELP!!!!
Old Jan 19, 2010 | 09:14 AM
z06eateR's Avatar
Icon2 AUTOMETER OIL PRESS. T FITTING...HELP!!!!
wats up. i've been searching and searching and cant find ****! i need to know were i can get a new 3 way "t" fitting for my oil pressure sensor...im running turbo...so i need the fitting for oil press. sensor...oil press gauge...and oil line for turbo...
can someone help me out as to were to find one of these... idk why i cant find it! idk wat size or "material" fitting either... any help would be appreciated. thank you...
Old Jan 19, 2010 | 10:34 AM
dpetro1's Avatar
Default Re: AUTOMETER OIL PRESS. T FITTING...HELP!!!!
everything should be 1/8npt threads. go to a local hardware store, im sure they will have a tee, they are usually just brass material. or if you want you can get an aluminum earls fitting
also note that if you want to maintain the oem oil pressure sensor it is 1/8" bspt threads so it may not seal properly with 1/8" npt. IMO it isnt really needed since it just a switch that come on below 5psi
Old Jan 19, 2010 | 10:55 AM
1992Si's Avatar
With 3 or 4 wraps of teflon tape the OEM sending unit will thread into the female 1/8"npt. Same with the 1/8"npt going into the Honda block. DO not over tighten the npt fittings. The tape seals not the over torque.
There are a number of on-line stores to buy this from.
Old Jan 20, 2010 | 07:22 AM
dpetro1's Avatar
mine always leaked slightly, but i was able to find an adapter from mcmaster-carr. i wish tunertoys was still around, they have a sweet adapter fitting for the block
evosix
Aug 26, 2013 07:33 AM
allmotorh22
Nov 23, 2006 01:23 PM
stockgreencivic
Apr 11, 2003 01:52 AM
b18cya
Feb 19, 2003 10:50 PM
slingshotsi
Sep 9, 2001 06:11 PM
