another oil line question
Old Nov 22, 2006 | 01:21 PM
allmotorh22's Avatar
Default another oil line question
Can someone show me pics of oil lines? I have a inlinepro manifold and I was wanting to see how they were ran and what kind of fittings are you using when you tap the oil pan. I did search but did not find what I was looking for
Old Nov 22, 2006 | 03:28 PM
stealthmode62's Avatar
Default Re: another oil line question (allmotorh22)
Here's a little write up I did with some pictures to give you the idea.
The source of oil for your turbo is the starting point of creating your oil line kit. Most vehicles use the factory oil pressure sensor as a starting point, while some cars use other areas such as the head or directly off the oil pump. Our kit can be made for any source, though the majority of our customers use the factory oil pressure sensor.
Our custom block fitting uses this sensor port to pull the oil source while retaining the factory oil pressure sensor function. Virtually all oil pressure sensors are a rare 1/8 bspt, and are a very difficult thread size to find. Our block fitting has the correct 1/8 bspt male threads for the oil pressure sensor port, and a 1/8 bspt female port on the back to retain the factory oil pressure sensor. Off the sides of the block fitting are two 1/8 npt female ports to create the oil source. When only using one port the other is plugged with a 1/8 npt plug. Here's a picture of the block fitting:
Installed into the oil pressure sensor port:
Once you have determined where your oil source will be, then you will need figure out how you would like to route your oil feed line, and measure how long it will need to be. Measure from the oil source to the turbo oil inlet. Our feedlines are 48" and are long enough for virtually all engine bay dimensions. If a longer line is needed, feel free to send us an email.
<FONT SIZE="16pt">Measureing the turbo</FONT>
There are two measurements of turbos that make the oil line kit interchangable. Here is how to determine the fittings you will need.
<FONT SIZE="13pt">Oil inlet thread size</FONT>- The oil inlet thread size is where the oil will enter your turbo. There are many different thread sizes, and some turbos aren't threaded at all. The easiest way to determine which thread size you have is to test fit differnt bolt thread sizes into the turbo until you find the correct one. Some standard sizes are 1/8 npt,
1/4 npt, 7/16 inverted flare, and an assortment of metric sizes usually a 10mm or 12mm with different thread pitches.
<FONT SIZE="13pt">Oil drain flange</FONT>- The other critical measurement in selecting which oil line kit will work for your turbo is the oil drain flange. By measuring the mounting bolt holes of your drain flange from center to center you can obtain this measurement. Standard drain flange measurements are 38mm, 44mm, and 50.8mm. In rare occurances there are other sized drain flanges. By ordering the next smallest size and opening up the mounting holes on the drain flange you can mount a drain flange on any turbo.
The drain hose is what will carry the oil out of the turbo and back into the oil pan. Depending on how far your manifold sets your turbo from the oil pan, you may need a different length of drain hose. Those with turbos further from the oil pan than 14 inches are encouraged to order our Universal Kit which has a 20 inch drain hose.
Installing the included barb fitting into the oil pan will allow the oil used to cool the turbo to be returned to the engine via the oil pan. There are many different fittings you can install. You can weld a 5/8 O.D. (Drain hose has 5/8 I.D.) length of pipe to the pan as well.
<FONT SIZE="13pt">How it's done</FONT>
Mount the turbo and manifold to get an idea of where it's going to sit. Either place or install the oil pan, and make a mark that will give you the best downward slope. It should be somewhere between the top and 1 1/2 inches down.
After you have it marked, make a pilot hole, and drill it out using a drill bit slightly smaller than the 3/8 threaded end of the barb fitting. Use your drill to slowly open the hole up until you can get the threads to "catch".
At this point your hole is where you need it to be to thread in your fitting. This is when I clean the pan completely with gasoline. Gas picks up all the metal shavings well. I slosh it around a couple times, a dump. I do this about 3 times and then wipe it down.
Start threading it in. Before the base of the barb fitting gets to the oil pan, you're going to want to use a sealer on the base of the pan around the hole. I use JB weld as well as alot of customers I hear from. RTV would probably work as well as others. Put the sealer around the hole. Tighten down the barb fitting until the base of it touches the pan. I don't torque it on there, but I tighten it. After it's tight, put another layer of sealer around the base of it.
Old Nov 22, 2006 | 05:40 PM
xenocron's Avatar
Default Re: another oil line question (stealthmode62)
Doesnt look like this guy knows a thing about oil lines...
Old Nov 22, 2006 | 05:42 PM
aarontrini85's Avatar
not to knock your product i know ppl running them and they like them but i have heard bad things about having the oilpressure sensor hanging like that when you rev high it wobbles and can break
i usealy run a sandwitch plate from the oil filter it seems to work good but is a little bit more money
Old Nov 23, 2006 | 09:00 AM
Default Re: another oil line question (aarontrini85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aarontrini85 &raquo;</TD></TR><TR><TD CLASS="quote">not to knock your product i know ppl running them and they like them but i have heard bad things about having the oilpressure sensor hanging like that when you rev high it wobbles and can break
Having heard, and having had happen are two different things.
Old Nov 23, 2006 | 09:48 AM
AJxr's Avatar
i usealy run a sandwitch plate from the oil filter it seems to work good but is a little bit more money</TD></TR></TABLE>
everyone i know (not over the net!) that used a sandwhich plate had very bad leaking problems. im using a $5 sunpro brass oil pressure T kit from autozone. hangs about 2 inches off the block 3 months with no problems and this isnt the first setup ive used misc. fittings from autozone for oil feeds. also know of lots of other sucess stories from actual people, not just hearsay over the internet. also ive never heard of anyone having a problem with that above oil line kit.
yo stealthmode can i have a free one? haha
Old Nov 23, 2006 | 09:53 AM
komat's Avatar
Default Re: another oil line question (AJxr)
i run a t off the stock oil pressure sensor port and sandwish plate for over 10,000 miles. i havnt had a problem...
Old Nov 23, 2006 | 12:39 PM
abnaasefmb's Avatar
Default Re: another oil line question (komat)
I run stealthmode62 T and have not had any problems. I think the problems occurs when people over torque the T or the sensor into the block and I’ve seen more broken blocks from people over torqueing the stock sensor into the block, its only aluminum after all no need to torque it to 90 ft/lbs. If you don’t want the weight hanging off the back of the block because you have a bunch of oil line T’s stealthmode also sells a firewall mount kit.
Old Nov 23, 2006 | 01:23 PM
Default Re: another oil line question (abnaasefmb)
the fire wall mount is a nice way of doing it i have seen that and plan on doing our ew crx the same way
balbowskie
Feb 17, 2012 06:47 PM
808Army
Sep 16, 2009 02:13 PM
totsie7944
Mar 26, 2008 04:26 PM
Cisco93Lude
Sep 28, 2006 06:37 PM
cdog19
Feb 9, 2004 01:15 PM
