Attn: Vaportrail re: H22a blocks not being frm coated?
I heard you say awhile back that the ;92-96 motors were not FRM coated, and you could bore them/put in forged pistons without aftermarket sleeves...is this true? What leads you to believe this? Any pictures?
Re: Attn: Vaportrail re: H22a blocks not being frm coated? (GraphiteAccord)
Here is what happens though if you dont sleeve and run an aftermarket piston in an H series motor
Ask anyone who wants to build a motor right the first time, they will recommend in sleeving the block.
https://honda-tech.com/zerothread?id=317430
https://honda-tech.com/zerothread?id=222772
[Modified by GudeH23a, 2:56 AM 11/18/2002]
New User
correct, the 92-96 blocks are not FRM coated. This is easily discerned from the 97+ blocks that are, as they are open decked (as shown in picture) while the older blocks are closed deck.
Re: Attn: Vaportrail re: H22a blocks not being frm coated? (VaporTrail)
ok, well im looking in my 93 helms book and i quote "The cylinder block is made of aluminum alloy using fiber reinforced metal (FRM) sleeves" page 5-3 in the engine section
it also talks about it on page 5-14...i'll quote that too if you like
[Modified by fastludeh22, 3:23 AM 11/18/2002]
I hate to disagree, but they are. Didn't the open deck blocks start with obd2? Having the closed deck does not indicate a different cylinder material.
Re: Attn: Vaportrail re: H22a blocks not being frm coated? (apexii)
All the H blocks are the same, I ran Forged pistons in a 94 H22 bored .040 over and got the exact same results as Gude H23.
Re: Attn: Vaportrail re: H22a blocks not being frm coated? (Robb)
All H-series blocks have FRM sleeves.
FRM is NOT a coating. It's a material that is an integral part of the entire sleeve.
1 Post
Does any of this have to do with the tighter clearances of the H22a Pistons?
I believe they run a Piston-Wall of .001? Those JE Pistons, etc...cant run that close of clearances...therefore scuffing, etc.
Suprdave
Suprdave
Vaportrail, can you explain some stuff...what pistons, what was your piston to wall clearence, how much over bore did you do, what rings, what kind of break in time/process. Also, what wristpins you used. if anything I'll just send my block to you and you can assemble the bottom end? will you garruntee anything?
Re: Attn: Vaportrail re: H22a blocks not being frm coated? (BoostedH23a1)
do you have experience with this boostedh23? iVaportrail has, he claims to have done it, and he is a creditable source of info.
