Attn: LS Turbo Guys
Re: Attn: LS Turbo Guys (quikrpm'z)
200.3 whp/ 223.7 wtq @ 8psi d-series greddy kit intercooled W/ blue box
stock b18b
[Modified by donniEK, 1:49 AM 2/25/2003]
stock b18b
Re: Attn: LS Turbo Guys (donniEK)
I'm hoping for around DIRep's numbers when i finally get it tuned in march...hoping for around 300 w/ the b16 head and gsr cams on it
look for a post in the future
Re: Attn: LS Turbo Guys (Hatch4urSnatch)
189whp 167tq @ 8psi
automatic, stock block yada, yada.. its all in the sig
How many times a week does this post get started anyway? I can barely keep up.
Anyhow, i made 220 whp and 194 tq on 7 psi running lean and on a stock fuel pump. 11 psi would estimate about 265-270 whp--based on a horsepower calculator for the 12.7 ET that I ran.
New fully built LS. Hoping for 400 whp....which should be very easily attainable, even on stock cams (crosses fingers)
Re: Attn: LS Turbo Guys (93LSivic)
i need to get mine dynoed but my ride is still for sale. Might still get it dynoed. I did do a a 1/4 mile pass of 12.67@114 on a 2.0 B18b1 motor. Had mad wheel spin but caught in 3rd and took off. Hopefully i do get dyno results.
LS motors
LS motors
Re: Attn: LS Turbo Guys (2.0L Turbo)
403 hp/295 tq with 19 psi of boost using C16 fuel. The engine could handle more, but I would say this is good enough for me (FOR NOW)! I only use race fuel on my car (C12 upto C16, whatever is available), but again, this is not my daily driver! With my full interior, I consider it...a street car!
Yeah, daily driven. In fact I just drove to work this morning in it. It only puts down like 318hp on pump gas & 15psi though. Can probably take that a little higher with some dyno tuning. And that's partially tuned (ie. untuned) because we got kicked off the dyno after only 2 or 3 pulls. Haven't had a chance to go back since.
Re: Attn: LS Turbo Guys (CheezeFrog)
Those numbers are really good. Care to share any of the setup. turbo size, sleeves? stock cams? headwork> blah blah
Re: Attn: LS Turbo Guys (g2turbo)
look at sig
THAT's from a non ball bearing T3T4 turbo at ONLY 14PSI with Motorsport 103 gas.
oh yea almost forgot, the LS head is STOCK with only cam gears.
FULL STREET/Daily driver in the summer
[Modified by Turbo_EK, 6:10 PM 2/25/2003]
I would have to say that you might have your numbers backwards. More like 223 whp and 200 tq. If not then you have a pretty sick curve
Hp/Tq? It'd sure as hell be nice to know. I maxed out a set of 450cc injectors at 8psi above 5500 rpm. So i'm guessing 250whp-ish @ 8psi. That's my low boost tho. I run 12~13psi as high boost, but I've got no clue what kind of power that amounts too. I'm hoping to make close to 400whp @ 20psi on my setup.
93LSivic know's what i'm running
The Civic Project
12-29-2004 02:19 PM
