Apex'i VAFC Q's
Guest
Posts: n/a
Hey guys i was planing on getting turbo soon and a Apex'i AFC and i was wondering if i would have to replace my stock map sensor because it does not work with boost or if the AFC will fix that, also how much would it cost to get my car tuned, right when i get my turbo i will be using the blue box but i was wondering if it would be ok to install the AFC before i goto get it tunedor if it would be better to install when i get there because it is a two hour drive to the nearest place that i trust to tune it right and i don't want to mess anything up on my way down there, and last what should my vtec engagement point be.
Thanks for the help.
[Modified by BLACK DEATH, 3:35 AM 2/25/2003]
Are you using a Greddy turbo kit? If so, you keep your stock map sensor. If you're using the Greddy blue box, it should be tuned already if you use the 310cc injectors that come with it. AFC does not correct map sensor readings for boost, but alters it so you can lean or richen the AF mixture. Just make sure you set the initial settings correctly : car select, sensor type, etc.
If you're not using the Greddy blue box, then you need a missing link or check valves.
igo4bmx
Mar 5, 2004 06:14 PM
