Apexi VAFC
Old Nov 11, 2005 | 11:03 AM
CRX 2.0V-T's Avatar
Default Apexi VAFC
lets say i dont have the money to buy Hondata, so can i use Apexi VAFC instead to control RC 750cc? Would it be ok?
Old Nov 11, 2005 | 11:05 AM
yee SERIOUS's Avatar
Default Re: Apexi VAFC (Lak of Speed)
uhhhhhhh....vafc tune 750's? i've never seen that before....
Old Nov 11, 2005 | 11:55 AM
gotboost95's Avatar
I think anything is possible. But you would have to run very low fuel pressure to make it work. The AFC limits you to -50% fuel over stock the injectors being almost triple the size of the stock injectors would make hard to tune. Your timing with the AFC is also very crazy.
A better and safer way to go about it is to handata or uberdata the car. All that takes is chipping the ECU and having it tuned. Then you wouldn't run into the timing issue Like with the AFC.
Good luck.
Old Nov 11, 2005 | 12:46 PM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: Apexi VAFC (gotboost95)
VAFC's tunability runs out at 450's
Old Nov 11, 2005 | 04:00 PM
PRELUDE-GT35R's Avatar
VAFC Bad idea
Save little more $$$ and get Hondata
Old Nov 11, 2005 | 04:15 PM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: Apexi VAFC (PRELUDE-GT35R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PRELUDE-GT35R &raquo;</TD></TR><TR><TD CLASS="quote">VAFC Bad idea
Save little more $$$ and get Hondata </TD></TR></TABLE>
Not terrible if you're broke But yes Hondata is better
Old Nov 11, 2005 | 10:15 PM
ppfalcon's Avatar
Default Re: Apexi VAFC (Vt4cPwn35)
get a fmu and run a 3:1 ratio plate that is the lowest they make..and get an FPR and electric fuel pressure gauge, you should be able to get by with the help of a decent wideband..
but if you need that much fuel you are making some power and cutting back on something like tuning can ruin all your hard work!
00BoostedGSR
Aug 1, 2006 10:46 PM
TypeR Chris
May 8, 2004 05:11 AM
dimotorsports
Apr 1, 2004 10:29 PM
_Endless_
Jun 20, 2003 10:07 PM
GQ 05YellowEVO8
Sep 24, 2001 04:51 PM
