Apexi turbo timer install?
Old Feb 25, 2002 | 10:17 AM
cool's Avatar
Default Apexi turbo timer install?
I have the Apexi turbo timer.
My question is where do I connect the three wires that supposs
to go to +12V, 1IG, 2IG on a 94 honda civic SI. I need specifics or
pictures. Thanks for your time.
Old Feb 26, 2002 | 02:35 PM
td04civic's Avatar
Default Re: Apexi turbo timer install? (cool)
the wires are by the steering column where the key is.
Apexi...94si wiring
power..white(it's a fat white wire)
ig1......yellow
ig2......black/yellow
hope this helps. good luck
Old Nov 9, 2004 | 12:14 PM
egturbo's Avatar
Default Re: Apexi turbo timer install? (td04civic)
im in of instructions.. i got apexi tt pen one and no instructions mines the one w/ o/2 reading battery etc.. can anyone help"?
Old Nov 9, 2004 | 01:12 PM
MrBui's Avatar
Default Re: Apexi turbo timer install? (egturbo)
have you tired out http://www.apexi-usa.com and look under documentation? its pretty staight forward just installed it last night. black wire goes to ground, white goes to o2 sensor, and gray goes to your park brake. take your steering colum cover off so you can have access to the wires to the ignition. and just tap into it. unplug youre battery so you dont shock yourself
Old Nov 9, 2004 | 03:16 PM
egturbo's Avatar
Default Re: Apexi turbo timer install? (n20need4vtec)
how about that white plug that comes out of the relay? i dont have the other end. what do i do? the white plug has green/blue/red wires going into it let meknow thanks.
Old Nov 9, 2004 | 04:02 PM
MrBui's Avatar
you can A: use spade connectors and tap into the 3 wires or B: cut that plug off and just lengthen the wires and tap into batt,ign1,ign2.
Old Jan 11, 2013 | 07:45 AM
ramizhood's Avatar
where do hook up the apexi turbo timer wires to?on a 1990 civic si
Old Jan 11, 2013 | 08:00 AM
wantboost's Avatar
Who is Mr Robot?
Wow... an 11 year old thread.
Why don't you read the instructions that came with it, read your factory service manual and go from there
Or Google it
SteveO000000001
Nov 6, 2006 02:00 AM
fourv2
Jun 24, 2005 04:03 PM
98teg
Oct 8, 2003 01:34 PM
Maverick77
Dec 31, 2002 12:38 PM
LordVtec
Oct 27, 2002 01:54 PM
