Apexi Turbo Timer Help
Old Oct 27, 2006 | 12:23 PM
SteveO000000001's Avatar
Default Apexi Turbo Timer Help
I have an apexi pen style timer in my turbo prelude..
I hooked the wires up the following way:
Car Turbo Timer
White/Black - Red
Yellow - Blue
Black/Yellow - Green
Ground it to a bolt on the fire wall - Black
WHen i take the key out the car shuts off..but if i turn the key one notch over (would usually shut the motor off) the car keeps running and times down, but like i said if i remove the key it shuts off.
Hopefully this is just a simple mistake on my end....
Also where do i tap the o2 sensor wire into.
Thanks
Steve
Old Oct 28, 2006 | 07:49 AM
bumpppp
Old Nov 6, 2006 | 02:00 AM
ALLMOTORCRX20's Avatar
Default Re: (SteveO000000001)
The white wire from the apexi auto timer goes to the oxygen sensor signal wire. Im guessing the oxygen sensor in your prelude is a 4 wire sensor. If this is the case, then it should have 2 black wires, 1 green and 1 white. The white wire from the auto timer goes to the white wire on the oxygen sensor.
:mR. PotAtO heaD:
Oct 8, 2007 08:55 PM
Ronan
May 22, 2007 08:48 PM
bluez6
Jul 15, 2006 11:41 PM
V3locity
Jul 24, 2004 06:32 PM
Maverick77
Dec 31, 2002 12:38 PM
