apexi for turbo setup ecu managmend
Re: apexi for turbo setup ecu managmend (doood)
You'll probably get the whole hondata/crome/neptune bandwagon in here if you don't point out that you live in Germany. Not many of those USA-based products are popular over there.
It really depends on the guy doing the tuning. You could have the best NA V8 tuner working on your turbocharged honda with an AEM ems, and theres a good chance it won't make nearly as much as a seasoned Honda tuner using uberdata. Find a reputable tuner, then see what they use the most over by you.
Re: apexi for turbo setup ecu managmend (HiProfile)
can i use this with new 3 bar map sensor
http://www.greddy.com/products...ry=47
for turbo ecu setup..
Moderator
Re: apexi for turbo setup ecu managmend (TURKISHFORCE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TURKISHFORCE »</TD></TR><TR><TD CLASS="quote">can i use this with new 3 bar map sensor
that is a DENSO pressure sensor that is used for e-manage, and is also used in the Power FC, though you need the connector harness to plug into the FC ECU.
Again, which are you planning on using? You sound very vaque and indirect.
Re: apexi for turbo setup ecu managmend (TheShodan)
all right , i make it on this company http://www.mkr-turbo.de/
