APEXi SAFC Adjustment
Old Mar 2, 2005 | 08:32 PM
Johnny_Rocket's Avatar
Default APEXi SAFC Adjustment
Alright, I just completed my turbo setup on my 93 Integra LS (B18A) My question is that I dont know of any local shops that will tune my car. I just want to get a rough idea of where to set everything on my Apexi SAFC until I find someone who will tune it up for me. If anyone has a turbo LS and is running a SAFC please let me get a rough idea of where your settings are at. Thanks!
Old Mar 2, 2005 | 08:35 PM
beepy's Avatar
Default Re: APEXi SAFC Adjustment (JohnnyH)
Adjustments on both high and low throttle scales should be:
(0.95 - (stock injector/new injector))x 100%
So putting 450cc injectors where 270cc were stock would be:
(0.95 - 270/450) x 100% = -35%
THat should get you close.
Old Mar 2, 2005 | 08:40 PM
Default Re: APEXi SAFC Adjustment (beepy)
I'm running stock injectors. What about the increased fuel % at set RPM's? From what i can tell from running it a little bit it will Boost around 4,500 RPM's... What should I set the fuel % at and at what RPM levels? Sorry if it's confusing
Old Mar 2, 2005 | 08:55 PM
dustin's Avatar
Then you don't really have anything to tune with the SAFC. What are you using for a fuel system? FMU?
Old Mar 2, 2005 | 09:28 PM
egturbo's Avatar
Default Re: APEXi SAFC Adjustment (dustin)
i just finished installed my safc II also installed 450's and it runs ok.. i just need to retard the timing my timing is at 17 right now. where should i set it at? cuz when i gun it i can hear like rocks going around in my engine is that detonation?
Old Mar 2, 2005 | 10:03 PM
dustin's Avatar
Default Re: APEXi SAFC Adjustment (egturbo)
Hmm I'd retard the timing until you don't hear rocks in your engine.
skunkedteg108
May 10, 2006 04:05 PM
JDM97R
Oct 20, 2004 11:06 PM
sneakypete
May 22, 2003 03:08 PM
spooler
Apr 11, 2003 12:26 PM
