Apexi S-AFC
Old Sep 3, 2002 | 07:30 PM
CzanSOHC's Avatar
Default Apexi S-AFC
I have my pressure sensor set to 6 in and 6 out ...when i do the sensor check everything looks good. but when i go to the monitor screen I get no reading for the Air flow, just 0% acrros the board...across all RPM levels ..but then i had it on Hot wire 1 in and 1 out...i get a air flow reading on both the sensor check and monitor. Why is this?
It is installed on a 1998 d16y7.
Old Sep 3, 2002 | 07:53 PM
cjmech's Avatar
Default Re: Apexi S-AFC (CzanSOHC)
the air flow only works on vehicles with a mass airflow sensor like toyotas, and other such vehicles, for honda you need it set on pressure 6in 6out so you will not get the kar readings or airflow readings.
Cj
Old Sep 3, 2002 | 08:06 PM
CzanSOHC's Avatar
Default Re: Apexi S-AFC (cjmech)
ok....i see....but if it only works on thoses types of cars...why do i get the reading?
accordselux
Nov 27, 2007 05:34 PM
iwantspeed
Honda Civic (2001 - 2005)
11
Jan 5, 2007 07:20 PM
djwest24
Mar 21, 2004 09:24 AM
ntegls
May 19, 2003 10:40 PM
freeplay
Nov 16, 2002 05:42 AM
