Apexi Electronics AVC Type-R Boost Controller
Old Mar 29, 2005 | 06:53 AM
eag36's Avatar
Default Apexi Electronics AVC Type-R Boost Controller
I was looking into boost controllers and I saw that the Apexi AVC Type-R Boost Controller has features like gear and rpm dependent boost settings. Does anyone have this boost controller and if so how do you like it? Also, how does it know which gear you are in? Does it guess based on speed or is it hooked up to both speed and rpm sensors? Is it easy to set up? Any info would be greatly appreciated.
Old Mar 29, 2005 | 06:55 AM
Civicman86's Avatar
Default Re: Apexi Electronics AVC Type-R Boost Controller (eag36)
I have hear the gear dependant boost is a PITA to setup but nice if you finally get it working.
Old Mar 29, 2005 | 07:27 AM
Bulldogg83's Avatar
Default Re: Apexi Electronics AVC Type-R Boost Controller (Civicman86)
Had the AVCR Boost Controller, and the Gear Dependant Boost Controll is really not that hard to setup. There is an extremly good write up by Blown90Hatch here:
https://honda-tech.com/zerothread?id=1037051
Old Mar 29, 2005 | 08:10 AM
underpressure02's Avatar
i got it I like it. More of a ricer toy for me to play with when I am driving then anything else. I thought I would use it more then I do but I could have gotten away a lot cheaper just using my aem ems as a boost controller.
Old Mar 29, 2005 | 11:06 AM
accord387's Avatar
^ sell the avcr adn use the aem ems.... thats what i'd do if i had AEM.
Old Mar 29, 2005 | 11:17 AM
adictionbass's Avatar
Default Re: (accord387)
can you have a low/high setting with the aem?
I got a brand new greddy profec b type s and the remote switching system i was going to be using iwth my hondata, but now im going aem. was planning on running something like 8-9 psi low boost and hitting the button when i hit third to switch to like 14 psi...
Edit: sorry for the thread jack....
Old Mar 29, 2005 | 01:06 PM
dustin's Avatar
Default Re: (adictionbass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adictionbass &raquo;</TD></TR><TR><TD CLASS="quote">can you have a low/high setting with the aem?
Edit: sorry for the thread jack....</TD></TR></TABLE>
Yes you can do this with the AVC-R. it has two "profiles" [A] and B and in each you can use a switch to add "duty" to the duty map to add boost when the button is pressed.
Old Mar 29, 2005 | 01:10 PM
Default Re: (dustin)
did you mean you can do that with the AEM?
dustin's Avatar
AVC-R, didn't notice you said aem.
Old Mar 29, 2005 | 01:11 PM
but can you have two switchable boost settings with the AEM EMS boost setup?
Old Mar 29, 2005 | 02:34 PM
TypeSLO
May 29, 2007 05:12 AM
type B16
Oct 30, 2006 05:32 PM
dominate9
Jun 24, 2004 02:16 PM
Kack
Aug 25, 2003 11:25 PM
