hondata ecu question?
i have a 2001 turbo prelude. was looking at getting a hondata, but wanted your guys input on weather to use a p28 or p72 ecu? anyone running this set up? what do you think?
Re: hondata ecu question? (boostedlude01)
You can run either the p72 or p28 ecu. It does not matter. The p28 ecu may even be a little cheaper and easier to find as well.
Khoi
Khoi
Re: hondata ecu question? (Sohc Driver)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sohc Driver »</TD></TR><TR><TD CLASS="quote">You can run either the p72 or p28 ecu. It does not matter. The p28 ecu may even be a little cheaper and easier to find as well.
Khoi</TD></TR></TABLE>
I think the reason he asked is cause 5G Prelude have IAB's just like a GSR. Maybe he's worried about loosing IAB control?
Re: hondata ecu question? (BlueShadow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueShadow »</TD></TR><TR><TD CLASS="quote">
I think the reason he asked is cause 5G Prelude have IAB's just like a GSR. Maybe he's worried about loosing IAB control? </TD></TR></TABLE>
I gotcha, but don't most guys get rid of the IAB anyways?
Khoi
Khoi
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedlude01 »</TD></TR><TR><TD CLASS="quote">i have a 2001 turbo prelude. was looking at getting a hondata, but wanted your guys input on weather to use a p28 or p72 ecu? anyone running this set up? what do you think?</TD></TR></TABLE>
if you still have the stock intake manifold with the butterflies then i would pick up a p72 ecu and have it socketed. Not to mention you can still use the knock sensor fo datalogging. with a motor that has been sleeved, might as well stop the extra cash on a p72.
if you have the skunk2 intake manifold, then pick up a p28 ecu, as its cheaper and with a knowledgable tuner you'll be fine for you timing.
Re: hondata ecu question? (seen4ever)
